Question about Home
Are there any good chemical free products to clean my grill pan with?
    Guru:
  • 269 Answers
I'll let you in on a little chef secret: White onion! Cut an onion in half, stab the round part with a fork. Heat up the pan or griddle and rub the onion across it. This will help remove all the gunk that gets stuck there.
Posted on Jan 10, 2013
My Bar B Chef grill grates are totally rusted. Are stainless steel grates better or should I stick with cast iron?
I prefer cast iron. Cast iron heats more evenly and retains temperature better. If they are falling apart from rust, junk them. If they just have surface rust and no holes, all you have to do is brush them with a steel brush at high heat. Wipe them off with a wet rag and then rub it with an onion to provide a teflon layer. if it is really heavy rust, spray oven cleaner on them and hose off. After use or for storage, clean them and then wipe them down with a cooking oil soaked rag. The oil will reduce rust build up.
Feb 28, 2015 | Grilling
What chemicals can i use to clean my gas braai,
I apologize I do not know what is a "braai" but since the category is "grills & smokers" I will proceed as though you were asking about a BBQ
Generally it is safe to suggest non-toxic cleaners like Simple Green because there is almost no chance of being harmed by this non toxic cleaner. However, non-toxic cleaners will need a lot of rubbing and scrubbing ad we usually want a chemical because we do not want to spend all day rubbing and scrubbing. Right?
We have been cleaning, maintaining and repairing barbecues for over 15 years and I still like Easy-Off a lot. Easy-Off is toxic but that means it will break-down greases and dirt and old marinades so they appear to be melting off the grill parts.
Please be sure to only scrub or brush grill parts made of materials that can be treated thus because coated grids (for instance) should not have abrasive brushing or the coating will scratch and oxidation occurs. Use heat, rough, green, 3m pads and degreaser for full safety and wire-wheel or sandpaper for real American stainless.
Anyway, I still like Easy Off after a very long time using hundreds of different agents. However, after cleaning make sure to clean-off the chemicals or burn-off for at least 10 minutes. Chemicals can keep you in the bathroom all week so be sure to rinse if you can (infrared burners cannot get wet) or burn-off the parts so there is no residue of the cleaners.
Feb 09, 2014 | Grilling
How to clean the grill and drip pan and get the grease and burnt on grease removed without hurting the finish on grill, lid/cover, drip pan, and the heat element
If you have a great amount of caked on grease build up, using a plastic putty knife is a good way to go. It won't scratch the finish and will remove the lion's share of the grease. Follow that, by scrubbing the remaining residue with a wet sponge and Simple Green in a spray bottle (it's biodegradable and won't hurt the finish.? Spray the Simple Green on, wait a minute or two and wipe of with a wet sponge. Rinse the sponge often Do not wet the heating element/burner. Use a grill brush to gently remove any any residue. Actually, it's best to remove the burner to clean it, because it also gives you the opportunity to clean the Venturi valve. As far as the drip pan is concerned, the plastic putty knife will work there too. In the future, lining the drip pan with aluminum foil, will eliminate having to clean it.
The grill grates can go in the dishwasher. Just do not allow them to go through the dry cycle.
My best advice on keeping a grill clean, is stay a head of the cleaning. Not allowing grease and residue to continue to build up. I say this, both as a grill dealer and as an avid professional grill-er.
Hope this has helped you. Please let me know and Happy Grilling!!
May 28, 2011 | Coleman 9928A50 Propane Grill
Where does air enter a new style gas fired water heater ? how do you clean the air intake area
Air intakes vary by brand and model.
Product manual has complete information for air intake, and yearly burner cleaning and maintenance.
1) You posted under Richmond heaters which is Rheem
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters/
For a manual, click on your product and next page has documents that download to your computer, including care and use manual.
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
Sample manual shows air intake is a grille located on side of tank.
Intake should be kept clean, and water heater never placed in room with dust, link or chemicals. Even trace chemicals will react with burner and prematurely corrode burner parts.
2) If you have Bradford White water heater, air intake is on side of tank through louvers.
3) If your gas water heater stands on 3-4 legs, then air intake is located on bottom of tank, making it difficult to clean unless tank is sitting on bricks.
Here is photo of air-intake screen on bottom of Whirlpool tank.
Tomorrow this heater is scheduled for installation, and it will be put on bricks.
On this specific model the front cover can be taken off, the burner cleaned, and cover put back on using same gasket, and without buying parts.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
My 2004 white convertible, I can not get it clean, its like new, never in rain or snow, only 11,000 miles, what is good product to clean it. thank you
If you are really particular about the looks get the chemicals at a Ford Dealer. You will pay more money but the chemicals are compatible with Ford products. In the aftermarket, anything made by EAGLE products will work well.
The problem with household cleaners for the interior is that the chemicals which remove grim will remove the chemicals for softness and anticracking agents. I like Fords' Custom Silicone Gloss for the exterior metal, but it is a light top coat- easy to apply and remove- and flows in lower temperatures.
Dec 31, 2010 | 2000 Ford Mustang
We are looking for a Fiesta Blue Ember (Model: FG50069-U409, Sierl #08UO19453) gas grill drip pan for grease; 20 1/4" X 9 3/4". Can you help?
Hi sir!
I'm wondering why you have not receive a free greese pan for your model. My guess is you are not aware that your model FG50069 is one from the list of RECALLED Fiesta Blue Ember products by the government due to safety and hazard issue.
see the link: http://www.blueembergrills.com/Safety/Safety.html
You can get it the greese pan for free due to recall issue. Just call the Blue Ember's phone is 1-800-396-3838
and they will send it right away.
For additional information, contact Fiesta Gas Grills toll-free at (866)740-7849 between 7 a.m. and 5 p.m. CT Monday through Friday, email mnorman@fiestagasgrills.com or visit the company's Web site at www.blueembergrills.com
I hope that is what you need, because there is a limit of this parts available in the market.
Please give this solution a good ratings
Thank you for using Fixya
Sep 20, 2010 | Fiesta Blue Ember Gas Grill
We have water leaking in the fridge and it smells, we have to clean it every day. It is 6 years old. It is frost free.
There is a pan undert the bottom of your ref it has a plastic line apx 3/8 inch around that goes up to your freezer it goes up the back of the ref on the inside or inside the casing. It goes to a pan in the top freezer this line has pulled loose or become plugged try cleaning it out and pour a small amount of 10% bleach water in the freezer grill this is a air vent grill in the freezer it will kill the bacteria that usually has the smell of garlic. good luck
Aug 08, 2010 | Frigidaire Refrigerators
Odor
Hi Sunlark,
I'm guessing your product is new -- the first couple of times you heat the elements, they're going to cook-off any chemicals that might have been on the plates as part of the manufacturing process. This may include any non-stick chemicals that might be bonded to the surface.
I personally try to avoid non-stick products as I'm leery of the Teflon/fluorine in the product, but I'm told I'm a little paranoid about things like that - - you have to use your own judgement.
If this smell persists after the first several uses, I'd contact the manufacturer's customer service people.
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Nov 10, 2008 | George Foreman G5 Indoor Grill
Llike to clean the grill of the oven without any chemicals
I have an Zanussi oven with grill. The model is zbf360x and I would like to know the best and most effective way to clean it.
Nov 03, 2008 | Zanussi ZHQ575 Electric Double Oven
Drip pan
HI rickieaknigh,
I'd contact the manufacturer (assuming it's a George Foreman product).
Go to
Product Warranty:
Jon
Aug 03, 2008 | George Foreman GR35TMRCB Indoor Grill
Home Logo
548 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
