Question about Kenwood SW36HT Subwoofer
Will fuses cause subwoofer to static - Kenwood SW36HT Subwoofer
Pioneer s-rs3sw sub. Power is on but why is there no control of volume?
Fuses blow when there is an overload. Unfortunately this saving action doesn't always save everything. If you fixed the part that was causing the fuse to blow, then that would stop that. It would not however correct anything that got damaged before the fuse lost it's life. Volume control these days is done by an IC. Sometimes these are static sensitive, and easily go out in fault conditions or maybe if you went near it without being grounded, when repairing the unit?
Oct 31, 2015 | Audio Players & Recorders
We had a static surge in house, no power to subwoofer, can it be a fuse? If so, can it be replaced?
Some powered subs have internal fuses that can be replaced. You will have to disassemble it to find out.
Aug 17, 2015 | Samsung HW-E550 Crystal Surround Air Track...
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Loose rca connection on subwoofer, causing static
that will do it if the RCA aint tip top you gana get static or a crackling noise sort the RCA out also is every thing grounded ?
Sep 20, 2013 | Car Audio & Video
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
Overhead car kenwood dvd player is constantly show disc error.. What is causing this error?
Possible error is the data is not read by the optical head.
So clen the lens eye to check if the faultt changes. If not the optical head assembly must be changed.
Use proper method to change the new Head, remove the static short of solder to prevent static damage to the head if touched or solderred by leaky soldering irons.
Use an anti static iron to do the job.
Sep 20, 2010 | Car Audio & Video
Subwoofer with screech and static
This sounds like the output stage of the subwoofer amp has failed -- needs service...
Charlie
Aug 22, 2009 | Definitive ProSub 1000 Subwoofer Speaker
My subwoofer is making a hissing noise when the truck is running and gets louder as the rpms increase. What could be causing this?
Engine static. There should be a supressor fitted to your audio system to counter this. it may be faulty. You can install in line ones via the power cable to your system.available from auto parts outlets.
Mar 05, 2009 | Rockford Fosgate Car Audio & Video
2001 ford explorer sport trax
probably exposed wires are touching something or they werent spliced very good,id check every point wher the wires were spliced together
Mar 25, 2008 | Bazooka BTA10100 Car Subwoofer
Kenwood SW36HT Subwoofer Logo
16 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
