Question about Dishwashers
Dishwasher will not run after filled with water
I can hear the dishwasher cycle start and usaully I can hear the water going into the tub but it only trickles in. When water is in the bottom of the tub it will not wash.  The cancel cycle works and drains.  this is a Kitchen Aide Model #KUDIO2IRWH1
  • 1 more comment
  • sahwell Jan 21, 2009
    I tried filling the tub with water and nothing happened. So sthat means the fill valve is bad and the float switch. So I should change both of the them coorect. Thanks
    No, when I manually filled the tub and tried to run it nothing happened. When I opened the door and raised the float by hand I heard a click from the float. Thanks
  • sahwell Jan 23, 2009
    Thanks for your help. But I ended up calling a repair man and he found a finish nail, a plastic piece stuck down by the motor and it would not run. Thanks again for the help and I like this web-site.
    Problem Solver:
  • 7 Answers
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Posted on Jan 21, 2009
  • jon sauers Jan 21, 2009
    does it fill to proper level on its own?
    turn power off,run float switch wires together try to start,if it wont run, the timer is bad! Make sure power is out before hooking float switch wires together!
When I push auto and start the lights go on and the time, but then it goes off. Why?
Hello. Is this unit less than 1 year old? If so, anything defective is covered under the warranty(parts and labor). After 1 year, certain parts are covered, however, no labor is covered. Make absolutely sure the door is closed properly--there is an internal door switch that must be closed(tells the main board it's okay to start the cycle) or nothing will happen and produce the exact symptom you describe. Next, the unit could be experiencing an error condition causing the shutdown. Make sure the water supply to the dishwasher is turned on(and always run the hot water in the sink before starting the dishwasher to ensure hot water gets to the unit). Next, do you hear the drain pump working? A lot of dishwashers turn on the drain pump immediately to remove any standing water in the pump before letting in fresh hot water. If the drain pump is jammed or clogged, you might hear a soft humming sound only(from the motor trying to spin) and then the dishwasher will shut down due to it detecting a malfunction. Check the float switch in the tub to make sure nothing has gotten underneath it(ex. a spoon or fork can become lodged underneath and the dishwasher thinks there is already water inside and won't fill) I hope this helps you!
Oct 12, 2015 | Maytag MDB4949SDH MDB4949SDH Dishwasher...
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
GE dishwasher (GSD4020Y73BB)is running the wash cycle w/no water
the load limit switch under the tub!! is bad that controls the fill level! and if its stuck closed the machine will do that its under the machine on the bottom of the tub
Jan 13, 2010 | Dishwashers
We use well water and I don't have a stainless steel dishwasher, so the tub has gotten very dirty looking with time. How do I clean the tub?
Make sure there is no detergent in the dishwasher. Put the dishwasher in "Rinse and hold" cycle and start it. Once you hear it starting to fill with water, open the door and pour in a cup of white vinegar. Resume the cycle. You also can try using some citric acid. If all that did not help try this.
Oct 20, 2009 | GE Nautilus 24" Built-in Dishwasher
LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
Feb 19, 2009 | LG LDF6810 Built-in Dishwasher
Whirlpool dishwasher will not fill with water
turn the valves to the left if there the screw in type or parraell if the quick open type the first thing a dishwasher does when you start it is drain for a few minutes then stops then fills with hot water run the water as hot at the sink as you can before starting the washer there is a float in the tub that can shut the water valve off if its not seated on the safety switch after the drain at the start of cycles stops then you should hear the water valve open and start the fill let me know and we will go from there
Mar 27, 2008 | Frigidaire 24 in. FDB126RB Built-in...
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Dishwashers Logo
551 people viewed this question
Top Dishwashers Experts
