Question about Kitchen Ranges
XMTE- 3000 temperature controller - Kitchen Ranges
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
Temperature fault. Q5N open
pls cheak by pas slecter not normal position load on by pas temperature fault 1st cheak coling water 2nd room temp 3rd cheak temperature sencer battary breakr to batt bank side 2 wair
Jul 25, 2013 | MGE UPS Galaxy 3000 UPS System
Show f3 on the display
F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
May 08, 2011 | GE Ovens
F-3 is showing on my oven display while in use and the oven shuts off.
The problem is the oven temperature sensor, this is located inside the oven near the top. For diagrams and illustrations of your specific model go to www.appliancehelponline.com and enter your model #
Apr 09, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Idle at 2500-3000
If you idle is high then your idle air control valve may be bad. (IACV) Basically what this does is changes the idle of your car during warm-up dependent on the temperature outside. When it is cold this valve makes it idle higher until it reaches operating temperature. If it is idling real high it could be that the valve is dirty or the electronics in it have gone bad.
Nov 19, 2009 | Honda Accord Cars & Trucks
Oven will not come on after replacing the probe. still gives an f3 code.
Hi
Thanks for using FixYa. F3 error code means the oven temperature sensor (above 3000 ohms) is open and you need to check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. If there is no wiring problem then you need to replace sensor. Please also check resistance of oven temperature sensor.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Acer Aspire 3000 notebook constantly overheating and shutting off
purchase what they call a chill pad... it plugs into a usb port on the laptop and has two fans... you set the laptop on top of it....
Robert
Jan 05, 2009 | Acer Aspire 3000 Notebook
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Error code 065 jjj jjjj jjj 065 (frigidair Model feb398ceb)
2 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace F2 Oven too hot Check Bake function F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F4 Oven temperature sensor shorted Replace component F5, 6, 7 EOC (Electronic Oven Control) failure Replace component F8 Lock switches Check or Replace component Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control) F2 Oven too hot Likely a bad oven temperature sensor (should read 1100 ohms) Possible bad EOC (Electronic Oven Control) F3 Oven temperature sensor open Replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control) Version 4 Failure
Code
Condition Check/Repair F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Nov 18, 2008 | Frigidaire Kitchen Ranges
Fault code F3, then F2
Well here's the details about those codes:
F2 :-
F3:-
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
194 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
