Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Ge Profile Top freezer-not cooling/not freezing
Manual defrost fixes problem for 2-3 weeks, then problem returns. Frost develops in freezer. One repair man came, said door gaskets need to be replaced. The gaskets are contacting well all around both refrig and freezer doors, so I am skeptical. I think maybe defrost not working. Where is access to defrost timer and heaters? Any way to manually over-ride defrost circuit in order to make it go into defrost cycle?
  • 11,896 Answers
Evaporator fan motor inside the freezer is working? Any frost on the freezer back wall?
This is the fan inside the freezer section, it will circulate the cold air around in the freezer and blow the cold air from the freezer into the fresh food section, it also sucks the warm air from the fresh food section back into the freezer to be re-cooled.
Hot condensor coils ( under the refrigerator ) been cleaned recently?
**GSS25LGMA**
That is part of a full model#.
Ge Profile Top freezer-not cooling/not freezing - 00082692.jpgEvaporator fan motor
Posted on Jan 21, 2009
  • Nate Stansfield
    Nate Stansfield Jan 21, 2009
    Also check the thermostat may be malfunctioning. Do you hear a clicking or anything different when you turn the temperature control?
    Also To check the defrost system, you can manually advance the defrost timer
    in the top of the refrigerator compartment to turn on the defrost
    heater. Take the cover off the refrigerator light. You will see the
    defrost timer behind this cover. Turn the timer clockwise until you
    hear the evaporator fan shut off.
    Check the glass tube heating elements in the freezer to make sure
    that they turn on. If the heaters do not work, you can disconnect
    electrical power and check the resistance of the heaters. Each heater
    is 7 ohms. You should measure 14 ohms of resistance through the heater
    circuit. I am showing blue and pink wires running through the defrost
    heaters. If you suspect that a heater is bad, look for black or burned
    spots on the ends of the glass heater tube. This would verify a heater
    failure.
    If the heater resistance is good, check the defrost
    thermostat. This thermostat will have pink and orange wires running to
    it. It should be closed (near 0 ohms resistance) at normal freezer
    temperatures. It is designed to open at about 60 degrees Fahrenheit. If
    it is open (infinite resistance), it will need to be replaced. Also,
    look for loose or broken wires in the circuit. After repairing any
    defective component, reconnect power and test the circuit.
    If
    your defrost cycle is working properly, your problems could have been
    caused by the water leak. After the water leak is repaired, observe the
    freezer operation.
  • Nate Stansfield
    check the defrost
  • 716 Answers
Remove Your Kick plate And It Should Have Instructions On How To Force Defrost. If Its Not There Unplug The Unit For 30 Seconds Then Plug It Back In Then Find The Temp Control In The Fridge Switch It Off Then On. This Should Force Defrost On Most Units.
In My opinion It Sounds Like you Need A New thermostat Or Timer If Equipped.
  • Michael Fisher
    Michael Fisher Jan 22, 2009
    The Access Should Be In The Actual Freezer Behind The Back Panel Inside. This Will Give You The Fan, Thermometer,Drain and Thermostat access.
    President:
  • 1,990 Answers
No way to Manually override these. You will need to Empty the Freezer and Remove the Shelves. Remove the Rear wall Panel inside the Freezer to locate these Components.
    Genius:
  • 1,665 Answers
If the freezer seems to be doing nothing, see the "It doesn't work at all" section, above. Otherwise, check these:
  • Is the thermostat knob turned to the proper setting?
  • Is the compressor motor running? It's a football-sized case with no apparent moving parts on the outside of the freezer at the back near the bottom. Is it humming or making any kind of continuous noise? If it is, but your freezer is still not cooling at all, there may be a serious problem with one or more of these areas:
    • The compressor
    • The condenser
    • The evaporator
    You can't service these yourself. You need to contact a qualified appliance repair technician.
The refrigerator stays at 47 degrees but the bottom compartments freeze
You have a defrost problem. A blockage of frost in the freezer prevents air flow over the cooling coils there, allowing very cold air to migrate back into the bottom of the refrigerator section. Unload the freezer and remove the back wall, melt the frost off the coils with a hair blower, and check to see if the defrost heater at the bottom of the coils is burnt out. If heater is OK, replace the 1.5 inch long white thermistor located at the very top of the cooling coils.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hi, my GE refrigerator has ice developing on the rear wall of the freezer, and things in my crisper drawer are freezing solid,please help!!!!
Unplug refrig. Empty all food from freezer side and remove shelves from freezer. Remove back metal cover from inside freezer. Melt frost with a hair blower. Examine defrost heater at very bottom of the coils you defrosted. If heater coil inside glass tube is broken, replace defrost heater. (note: replacement may look different, but insturctions included with replacement address that) If heater is not broken, replace the small white pencil shapped sensor at the top of the cooling coils.
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge running but not cooling
It sounds like you are having a problem with your defrost cycle. If your unit either does not go into defrost, or you have a defective defrost componet, it will cause your evap. to freeze. Hope this helps
Sep 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer frost then loss of cooling
There is a block of ice that is causing the air to not flow across the coils as it should. This is why the temp has risen. You can do a manual defrost by un-plugging the unit over night but I would call out a ref tech to check the defrost timer and the freon level. Hope this helps. Good luck. Please re-post with updates. Thanks cj2176.
Jul 13, 2009 | Fisher and Paykel Active Smart E522B...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
390 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Da Doc
