Question about Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator
Samsung rsa1ntpe noise - Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator
What is causing the noise on my samsung refrigerator, only when the door is closed.
Is it ievel....fridges and freezers make all kinds of noises if all 4 feet re not level......when you experience the noise,adjust feet and one at a time until hopefully the noise will disappear N.J.T.
Oct 25, 2017 | Samsung Refrigerators
I have samsung french door refrigerator 2 door 2 drawer with vibrating a noise. I have removed the back panel and the noise does not seem to be cominng from this area. any suggestions.
We have a different model Samsung, and I've heard a vibrating or buzzing noise twice. First, if the water filter isn't an exact fit (even Samsung's filters rattle), it will rattle. Second, if either of the ice makers gets stuck or jammed, it can make a vibrating noise. If our freezer drawer isn't making a good seal, ice will build up under the drawer or in the slides. Ours makes more of a humming noise, when this happens. Other areas to check: something stuck in the runner of your drawers or shelves (if yours pull out). There are also vents that draw air in and out of the cooling unit, and things in front of them may vibrate or rattle, too.
Jul 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung RSA1NTPE not cooling in either the fridge or freezer. Seems like the compressor is not running although it is hot too the touch.
the compressor is seized and wont pump and the motor keeps trying
to work and thats why its hot,sorry to tell you but you need a new
compressor
Aug 21, 2012 | Samsung Refrigerators
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung hln617w 61"
Most likely part is the Color Wheel, most people describe it as a grinding noise.
Jan 21, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator Logo
24 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
