Question about Refrigerators
Dazey stripper vegetable/fruit peeler - Refrigerators
  • 106 Answers
SOURCE: bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Posted on Jan 11, 2008
aasc
  • 1606 Answers
SOURCE: water running out from under vegetable and fruit
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Hook the other end , around the glass rod (defrost heater) carefully , to avoid breaking the glass , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Jan 01, 2010
SOURCE: vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Posted on Jan 07, 2010
Sea Breeze
  • 4655 Answers
SOURCE: food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Posted on Jan 20, 2010
BMT60
  • 126 Answers
SOURCE: My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Posted on Apr 24, 2010
BADLY SQUEEZES OUT VEGETABLES
Search Results
    45 Uses For Lemons That Will Blow Your Socks Off
    preventdisease.com/.../052713_45-Uses-For-Lemons-That-Will-Blow-Y...
    May 27, 2013 - You can make sure the white vegetables stay white by squeezing a teaspoon ... Slice your lemon and squeeze out one tablespoon of lemon juice into ... alters the pH level in your mouth, killing bacteria that causes bad breath.
    Bad news for vegetarians! Plants can 'hear ... - Daily Mail
    www.dailymail.co.uk/.../Bad-news-vegetarians-Plants-hear-eat...
    Daily MailJul 2, 2014 - Researchers in Bonn, Germany, found plants give off a gas when under 'attack'. ... The research could help to work out which pieces of fruit and vegetables ..... creates YouTube channel dedicated to spot squeezing - and her.
    The GP who gave up fruit and veg to cure her aches and ...
    www.dailymail.co.uk/.../The-GP-gave-fruit-veg-cure-aches-pa...
    Daily MailJul 16, 2012 - I slept badly - I suffered from restless legs and my muscles kept ... cutting out virtually all 'healthy' food - I avoided most fruits and vegetables, salads, ..... in a series of sold-out seasonal shows; Casey Batchelor squeezes her ...
    Market Dis. of Fruits and Vegetables: Citrus and Other
Dec 16, 2015 | Juicers
What is a potatoe peeler?
A peeler (potato peeler or vegetable peeler) is a kitchen tool consisting of a slotted metal blade attached to a handle that is used to remove the outer skin or peel of certain vegetables, often potatoes and carrots, and fruits such as apples, pears, etc. A paring knife may also be used to peel vegetables. A peeler differs from a knife in that the blade has a slot cut into it, which is sharpened on the inside edge, while the other side prevents the blade from cutting too far into the vegetable.
Aug 09, 2014 | Work Safety
My ebay login roy.suge3945@yaho.com
Refer this inquiry directly to eBay.
Jan 18, 2014 | Computers & Internet
What kinds of kitchen slicers are there?
Kitchen slicers can be of different kinds.
There are the mandolines, flat, generic slicers that make thinner and thicker slices of most kinds of hard fruits and vegetables.
There are the more specific kinds, that cut specific foods into specific shapes, like egg slicers or banana slicers, or apple slicers, or slicers that peel the fruit and remove the pit, like for pineapples, cherries and mangos. Of these specific kind there are many variations. There are twisters, that make thin twists of vegetables, usually used for carrots. There are spiral peelers, like for apples or pineapples. There are dicers that split the fruit in precise chunks.
And then there are the electric slicers, that shred and slice your food into bigger or smaller chunks or slices, for example to make fries by slicing potatoes into long thin rectangular pieces within minutes and with no physical effort.
Oct 24, 2013 | Home
Can fruits and vegetables be stored for emergencies?
No, unless they are canned fruits and vegetables. Regular vegetables and fruits will not last for a long period of time.
Feb 04, 2013 | Home
I am looking for replacement cutter blades for the Rival Stripper Electric Fruit and Vegetable Peeler. Do you know of a source for these parts?
You can approach the appliances dealerships to get addons or spares for the cutter .
If the Rival dealer is available you can get the spares or contact in the official site :
www.rivalproducts.com
Sep 29, 2010 | Vacuums
Vegetables in fruit and vegetable bin is freezing.
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
