Question about HP LaserJet 5si Printer
Paper feed my hp laser printer keeps showing load paper tray 1 but wont pick up from tray 2
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Posted on Mar 04, 2009
HP 4100dtn Tray 2 picks the paper NON-STOP?
Step 1:Check with another cartridge
Step 2:Switch off the printer take out tray 2 casette, swich on the machine check while intializing the printer tray 2 pick up roller rotating?.. If its rotating check solnoid which is located right side under the main moto assembly, clean the solnoid as shown in the anap shot..fix it back.
Step 3:Open right ,left & top covers.., close cartridge access door check is it driving the laser scanner shutter?, if not check the sccess door knotch broken/bend.
Nov 20, 2011 | HP LaserJet 4100dtn Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Same problem. Printer runs but wont feed in any
observe if pick up mechanism function as when you send printing job. if yes, may pick up roller already worn out and need replacement.
Jun 02, 2010 | HP Officejet 5510 All-In-One Thermal...
241.10 paper jam- couldn't find any paper jam. How do I clear the message?
Error Code: 241.10
Page was not properly picked from tray 1
Possible Causes
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Solutions
1. Fan media.
2. Turn media over.
3. Reduce amount of media loaded in tray 1
4. Replace pick tires.
Oct 29, 2009 | Lexmark T640 Laser Printer
Hp laser 4000 keeps coming up w/ 41.5 error
41.5 is a paper feed error, take out the paper tray and clean the rubber roller above where the paper goes with a cloth just damp with water. Dirt on that roller will stop it from picking up the paper.
Jul 09, 2009 | HP LaserJet 4000n Printer
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Can't print envelopes
you need to select tray #1, manual feed.
tray #2 is auto feed- 8x11 sheet paper.
Jan 29, 2009 | Dell 3100cn Laser Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
HP LaserJet 5si Printer Logo
558 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
