Samsung LN37A450C1DXZA has thermal looking picture
Where is the thermal shut off fuse located and what does it look like. DV331AEW/Xaa
The thermal fuse is located on the blower housing. You should check out this link to www.repairclinic.com
for a lot more info on this and other possible items that could cause no heat. The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160c44d1067187/Model-DV331AEW-Samsung-Dryer-Fuse-Thermal-Fuse-Breaker-Parts
Good Luck!
Rich Lilja
Dec 03, 2014 | Samsung DV331AEW Dryer
Need picture of thermal fuse to Samsung front load dryer
It should look like this one or a little bit bigger / different shape...
Show this picture to someone at lowes or home depot and they should be able to show you where it is...
I hope this helps you...
May 14, 2013 | Dryers
You will need the T-CON board replaced or serviced.
Here's a link for the later (also has a picture of the inverse colors picture effect you're referring to as "thermal"):
http://www.coppelltvrepair.com/p/828/repair-service-for-samsung-ln37a450c1dxza-t-con-board-causing-inverse-colors-or-other-image-deformations
Jan 09, 2013 | Televison & Video
Thermal fuse location
Ok go to this web page read the instructions for testing, then go to the sears.com page, parts direct and look up thermostats and go to the diagram for locations and test
http://www.ehow.com/how_2377924_test-dryer-thermostat.html
Jan 05, 2013 | Samsung DV219AE Dryer
Samsung tv's lcd picture is fuzzy and red
Samsung has had some issues with stands that are screwed in to panel have cause video issues from pressure to panel. Some times removing the screws from base can relieve this problem. From what you are discribing though i would think that you probably have a bad main board. You definitely need a technician to check this out.
Oct 22, 2010 | Samsung LN37A450 LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
