Question about Philips 14PT1356 14" TV
I NEED WAY FOR ENTER IN SYSTEM MENU TV 14PT1556/21
I don'have tone and i have short picture (Vertical)
  • Zdravko Rogosic
    Zdravko Rogosic Jan 23, 2009
    I dont have a tone , just picture, and the picture iz nerowed in the lower part.
  • Zdravko Rogosic
    Zdravko Rogosic Jan 24, 2009
    Yes, it doesn' have the sound. I know what is the problem
    but I need the code or a way for entering in the service mode. I just don't know way the sound isn't working, when the exiting amplifier for the sound and the control for the amplyfiing is working OK.
Mipos mpori kapoios na me voithisi eo thn philips 14pt1356/01exo xionia sta kanalia kai den exo foni
Posted on Jul 30, 2010
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, to my understanding, the vertical fault is hardware and therefore adjustment in the service menu would not correct it. You might have better results checking the vertical components including the pump capacitor, the IC and the resistors within the area. You might also check the vertical supply voltage coming from the FBT. This of course requires familiarity working with electronic components & circuitry, use of a DVM/VOM and a soldering iron plus safe working practices with live/HV sections.
Pls postback to clarify the missing "tone".
Good luck and thank you for using FixYa.
Posted on Jan 23, 2009
  • Louie  Role
    Louie Role Jan 25, 2009
    Service Mode entry on some Philip's models:
    shorting the service pins inside the TV unit near the EEPROM;
    combinations keys on the remote controls. Pls appropriate codes here, here and/or reference this.
    Genius:
  • 1,550 Answers
What is your problem .Repost your question with some more details .
To enter into menu click menu button in remote.
  • SAM ANDERSON Jan 23, 2009
    • Look for a cold solder joint in the vertical drive, as well as in the area around the low voltage power supplies.See if there is a short in that area where there is a fuse to the vertical drive and audio stages that is shared by the two.
    • Check the caps in the power supply providing the low voltage to the audio and video processing IC's, and check the regulators/zeners .
    But still have doubt what you mean by missing tone .
    Does it mean sound is not working ?
    Please post back if you need further help .
    SAM ANDERSON
  • SAM ANDERSON Jan 25, 2009
    There are two ways to enter into service mode.
    • Option 1:
      In the TV-set itself is a 3-pin connector
      with which either SERVICE-DEFAULT or SERVICE-MODE can be activated. For
      the MG3.1E chassis this connector is depicted 0356 (SERVICE-PINS) on
      page K7 (TXT&CONTROL). Shorting pins 1-2 will activate SERVICE-MODE.
      Shorting pins 2-3 will activate SERVICE-DEFAULT.
      IMPORTANT NOTE: using the service pins will disable any software security feature!!
    • Option 2:
      Activate these modes using the remote control.
    Option 2 is the preferred method because the settings have to be changed using a remote control anyway....
    To activate SERVICE-DEFAULT:
    • Press 0 6 2 5 9 6 and then the [menu] button.
      The message 'Service Default' appears and channel 'SER T' will be
      selected. This only sets some settings to a preset value
      (channel/color/brightness/volume and such).
      This mode is primarily intended to set things to a predefined state for
      servicing. Measurements/adjustments are usually carried out with
      service default active. You can exit the service default mode by
      placing the TV into standby (not through the mains switch).
    To activate SERVICE-MODE:
    • Press 0 6 2 5 9 6 and then the [i+] button (Note: the [i+] button is also known as [OSD] or [STATUS] button.
      After pressing 0 6 2 5 9 6 the message 'Dealer' should have appeared.
    Other codes which seem to work:
    0 1 6 2 5 9 6
    0 3 6 2 5 9 6
    0 4 6 2 5 9 6
    0 7 6 2 5 9 6
    0 8 6 2 5 9 6
    These alternative codes have just an additional number after the '0'.
    The additional number is any number which was not part of the
    'original' code.
    More precisely: the number following the '0' can be repeated multiple times, so
    0 1 1 1 6 2 5 9 6 is also acceptable.
    Note: press the numbers not faster (or slower) than you would normally
    do if you had to press multiple numbers. Do not worry about the channel
    changing while you press the numbers.
    Source :http://majority.110mb.com/tv_matchline.h...
Rca 21k8. Insufficoent height
Warning!!!!!!!!!!
Do not adjust anything else only Vertical amplitude .1.1. The way to enter P-Mode a) Method one A) Switch on the TV set. B) Press the "MENU" key on RC to show the "PICTURE" OSD menu. C) Move the cursor to "Contrast" item then press the "9", "7", "3", "5" key continuously on RC within 3 seconds then enter P-Mode. The "P" letter will appear on the left low corner of the screen when enter P-Mode. China TV 21F1 NX56E LA Service Manual
Nov 25, 2016 | RCA Televison & Video
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
I change the color setting in my tv by accident and now i dont get green or red to show it shows brown how do i correct the setting
hello there,
Your TV has three automatic picture settings ("Dynamic", "Standard", "Movie") that are
You can activate a Picture Setting by making a selection from the menu.
1 Press the MENU button to display the menu.
Press the ENTER button to select Picture.
2 Press the ENTER button to select Mode.
Press the ? or ? button to select the Dynamic, Standard, or Movie picture setting, then
? Choose Dynamic for viewing the TV during the day or when there is bright light in the
room.
? Choose Standard for general TV watching mode.
? Choose Movie when watching movies.
Press the P.MODE button on the remote control to select one of the standard picture
settings.
3 Press the ? or ? button to select Contrast, Brightness, Sharpness, Color, or Tint,
4 Press the ? or ? button to decrease or increase the value of a particular item.
? You cannot adjust the Tint in DTV, Component or HDMI mode.
5 Press the ENTER button to return to Mode.
6 Press the ? or ? button to select Color Tone, then press the ENTER button.
7 Press the ? or ? button to select Cool2, Cool1, Normal, Warm1, or Warm2, then press
the ENTER button.
? When the picture mode is set to Dynamic or Standard, Warm1 and Warm2 cannot be
selected.
8 Press the ? or ? button to select Reset, then press the ENTER button.
? Each picture mode can be reset.
there ya go if you need anymore help let me know and don't forget to Rate
Jan 26, 2011 | Samsung TX-T3093WH TV
How can I adjust the screen so I can see the score of the football game it is cut off on my Panasonic TH-50PX75U
Hello
To do this you have to enter into the service mode, ie, factory setting modes, which oly will allow you to do the screen adjustments. Your TV needs vertical S-Correction, to avoid lower side stretch. Four methods to enter into the service mode are given here . Just try OK.
In Sound-Menu Low-tone-regel to MAX and
High-tone-regel to MIN. Press 'F' button on TV.
Then press VOL- on TV and REVEAL on RC in
some time. Select: red and green buttons.
Adjust: yellow and blue buttons. Store:
'STR'. Exit: 'N' on RC.
High-tone-regel to MIN. Press VOL- on TV
and RESET on RC in some time. Select: red
and green buttons. Adjust: yellow and blue
buttons. Store: 'STORE'. Exit: switch off.
ON: Press simultaneously 'OFF TIMER' on RC
and 'CH.UP' local.
OFF: Press simultaneously 'OFF TIMER' on RC
and 'VOL-' local.
Simultaneously press 'RECALL' on RC and
'VOL-' local. Exit: 'NORMAL' on RC.
After entering into this mode, be careful not to spoil the set. Mark all the initial values on a paper for refernce, and begin to chage the values. You may only have to chage the value of "SC".
Nov 22, 2010 | Samsung TXJ3678 36" TV
Zenith tv picture is larger than screen
Hello
There are Horizontal and Vertical size controls behind the back cover that need to be adjusted using a hand held tool. This adjustment requires a trained tech. High Voltage from the set is dangerous.
However, there maybe some limited controls that may help through the on screen menu.
To get into the setup menu, you need the original Remote that came with the TV.
Hold the Menu Key down until a box appears in the corner of the screen, then press 9,8,7,6 Enter. this takes you to the service menu. Just scroll through the items to find Horiz Size and Vert Size.
Good luck
Dec 30, 2009 | Zenith H32G48S TV
SHORT PICTURE
it could be a setting in the picture menu it sounds like it is set to 4:3 there should be an adjustment in the picture menu on your set hope this helps regards Jim
Mar 31, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Vertical black lines rear projection
Please provide exact model from back of tv........
Possible vertical IC circuit problem===bad caps? IC?
...........T.
Nov 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Aug 22, 2007 | JVC AV-27320 27" TV
Mitsubishi WS-65807
OPTION MENU "MENU 8270" SERVICE MENU "MENU 8257" CONVERGENCE MENU "MENU 8259, 4 FINE, 5 COARSE, 6 MISC." Then you can also check by:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
May 22, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Philips 14PT1356 14" TV Logo
395 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
