Question about Canon PowerShot S5 IS Digital Camera
Cannot unlock memory card for my Canon Powershot S5IS
I somehow accidentally 'locked' my SD memory card and cannot figure out how to unlock it. I have read the manual but it does not seem to answer the question--any suggestions? Thank you!
  • Taylorboy714 Jan 21, 2009
    THANK YOU SO MUCH! I never knew that existed--this site is great!
  • verix Mar 09, 2009
    ok, I did it - I switched to the unclock positin, but it still says: CARD LOCKED ! what can I do?
    Genius:
  • 1,199 Answers
OK take out the memory card and on the side of the card is a small switch...slide the switch to the unlock posistion and that should fix ya
!Please rate this response and help us keep this area free!
Thank You!
Posted on Jan 21, 2009
  • viki896 Jan 26, 2011
    thank you so much. I had no idea that the memory card had a switch on it. I must have locked it by accident. I have not used my camera in months. "THANKS"
I have a Canon A650 that was displaying a "card locked!" message. First, of course, check the lock tab on the card itself. Then, try a different SD card in the same camera. I tried an old 256 MB card from an older camera. I still got the "card locked" message. When I put the 1 GB card I was struggling with in my old Nikon, it read fine. So at this point I knew it was my camera and not the card. What finally worked was very gently pressing down on the metal flap inside the card chamber that detects the lock with the tip of a straightened paperclip. When I turned the camera on again the problem was gone. Hope this helps.
Posted on Dec 05, 2009
Card lock for powershot S5IS
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 10, 2013 | Canon PowerShot S5 IS Digital Camera
Help with unlock memory card locked problem on Canon PowerShot SX120 IS
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 06, 2011 | Canon PowerShot SX120 IS Digital Camera
Card is locked
There is a tiny switch on the memory card that is used to lock to prevent accidental erasure. Make sure that this small lever on the side of the SD card is pushed to unlock.
Apr 06, 2011 | Canon PowerShot A650 IS Digital Camera
Cannon s5is powershot as soon as i turn camera on a memory card error comes up and theres no card in it, does same thing when card inserted. it's got to be something in the camera slot, is there a lock in...
On the SD card there is a little switch you can move. It has 2 positions, LOCKED, and UNLOCKED. To make the card available, put the switch in the UNLOCKED position.
Here is an example-
If that doesn't work, try putting the card into a memory card reader, like on your PC or a special USB attachment. If the memory card is recognized, then it might be a problem with your camera.
Mar 01, 2011 | Canon PowerShot S5 IS Digital Camera
Canon powershot s5is isn't connecting to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 10, 2010 | Canon PowerShot S5 IS Digital Camera
Card locked please help
There are two reasons for card locked problem Canon PowerShot A400.
One is card locked while camera opening. The answer for this is explained in below figure.
34a2e3d.jpg The other one is dealing with card itself. The below picture shows that.
68ed342.jpg You may need the user manual for other problems.
This is User Manual of Canon PowerShot A400
If you find this helpful please vote.
Mar 04, 2010 | Canon PowerShot A400 Digital Camera
Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Jul 23, 2009 | Canon PowerShot A590 IS Digital Camera
Camera won't read memory card!
Hi there and welcome to FixYa. There could be a couple of things off the top of my head that could be giving you the problem, so we'll try solutions for them both.
A) Go into the menu of your camera and format your cards. Your camera won't save pictures to a card properly if you don't format it first. - Go into the Setup menu for this. And remember, you have to format the cards in the camera, don't use your pc or a card reader.
B) The above will take care of your problem unless.... your cards are locked. SD cards have a switch on the side of them so you can lock the card (it prevents accidental erasure). In that case, unlock it with the switch on the side. Let me know with a comment if you have any questions or problems, or if either of these solutions doesn't do the trick.
Rob
Mar 01, 2009 | Canon Cameras
Memory card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 18, 2009 | Canon PowerShot A460 Digital Camera
No memory card.
I have the same problem with my Canon G9. I have found a solution and since doing it the problem has only happened once again. Here is the solution: I have a 32mb sd card that was given with the camera when I bought it. This card has different connectors than the ones that are used on the usual SD cards. As soon as this card is inserted the camera works properly and all other cards work fine after. I'm assuming that the sd card circuit blocks and this 32mb card unblocks it somehow... Hope this will help you.
Jan 12, 2009 | Canon PowerShot A75 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
331 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
