Question about Frigidaire FAC107P1A Wall/Window Air Conditioner
Stop the beeping please
My unit started beeping and seems to be going into sleep mode (I am not sure what sleep mode does), and I think it must snore by beeping. I have a rental place and this is the unit that was provided without any information about it. The only way that I have made it stop is by turning on the timer(not really sure what it is timing either). Is there an instruction hand book on line. Can you tell me how to stop the beeping
  • Chalrlotte hayes Jul 03, 2007
    The manual says nothing about the beep beep beep beeping... but thanks for the manual! I think a figured out that the timer times how long a I have till the thing starts beeping again (very useful *sigh*). I really want the beeping to stop or I might push the window unit the rest of the way out the window. The sleep button blinks on and off too... any clues?
  • rosythlass Dec 31, 2007
    argh - stop the beeping....pleeaaasseee!!! Motorla Me4061 cordless phone - hpw annoying
If youre anything like me, you have a mechanical inclination and the desire is bad enough to fix this problemn yet unable to buy another... The way i fixed this infernal beeping & the sleep light cycling on & off everytime is as follows
Disconnect Power...Pull the filter cover & filter off....Locate the 2 screws that hide behind the filter that hold the front panel on & remove them..You should then just have clips on the sides that you can easily pop it out of...You will find that a cluster of wires housed by a black shield runs to the control panel in the part u just removed..There should be 3 screws to remove in order to open the compartment that houses the control board....Remove the screws holding the control board in and remove control board...On that board you will see there are buttons and one of them will say sleep....YOURE ALMOST ON YOUR WAY TO QUIET NIGHTS AGAIN.....VERY CAREFULLY pop the top of that button housing off ( I used a utility knife ) BE EXTREMELY CAREFUL NOT TO TEAR ENTIRE BUTTON OFF OF THE BOARD....once the button top is off you will see a small circular piece of metal that is pushed down when the button is pressed...KNOCK THAT PIECE OF METAL OUT AND VOILA THE BEEPING WILL NOW STOP BECAUSE IT HAS NOTHING TO HIT THE CONTACTS IN ORDER TO FORM THE CIRCUIT.... I am going on 2nd day now noise free & did not have to buy a new unit since mine cooled just fine
HOPE THIS HELPS....If you need further assistance you can email me at jasondupree1980@yahoo.com
Posted on May 03, 2012
  • jasondupree1
    jasondupree1 May 04, 2012
    I also posted how to pull the metal contact out of the SLEEP button..What happens in these units is that the button goes bad and constantly turns itself on & off...Well as you may notice if you pulled the unit apart following my last post that the SLEEP BUTTON is soldered onto the control board..Well removing the SLEEP BUTTON can be done in a number of ways..You can use a knife & CAREFULLY PRY BETWEEN THE BOTTOM OF THE BUTTON & THE CONTROL BOARD or you can use a soldering iron to melt the existing solder & use needle nosed pliers to pull the button as your melting the solder... Either way, the rest of the control board will work as long as you do this CAREFULLY and make 100% sure not to melt solder on something else or break anything....I SUGGEST USING A KNIFE TO CUT BUTTON IN HALF BECAUSE MELTING THE SOLDER CAN CAUSE THE OTHER SOLDERED CONNECTIONS TO HEAT UP AND BECOME LOOSE IF YOU DO NOT USE THE SILDERING IRON RIGHT....Once the button is broken, simply grab it & move back & forth until the legs break off of the control board....IF SOMEHOW YOU MAKE THE CONNECTION & ACCIDENTALLY TURN THE SLEEP MODE ON, {NO WORRIES} SIMPLY TAKE THE KNIFE & TOUCH THE CENTER OF WHERE THE BUTTON WAS ON CONTROL BOARD & THE SIDES WHERE THE METAL LEGS CAME UP FROM BOARD TO BUTTON MAKING THE CONNECTION THRU THE KNIFE & DISABLING SLEEP MODE { or use the remote if you have it} If you do this correctly, There will be NO WAY for the sleep mode to be turned off & on like it was doing before unless you pull unit open & do it or use the remote....I FURTHER SUGGEST, if you dont use the remote regularly, take the batteries out of it that way there is no chance of sleep mode being activated and you will once again have BEEPLESS NIGHTS & DAYS
    Hey as far as the beeping window unit a/c i found that in some instances pulling the metal contact out of the button on the control board may not work all the time....
    If this is the case and you still have a beeping unit follow the steps to pull front panel off and remove control board (the board with the temp display & power buttons) Instead of removing top of the button & metal contact inside, simply pull the entire switch off....This will not affect the rest of the controls, it will however make sleep mode im possible to use unless you use it from the remote...
    IF YOU HAVE ANY FURTHER QUESTIONS OR NEED FURTHER ASSISTANCE ON THIS MATTER PLEASE FEEL FREE TO E-MAIL ME AT
    I have had to do both steps on this particular unit as i have multiple units like this at work and had to do it on my unit at home & know all the details of it so best of luck to you. If this does not work for you please let me know thru E-MAIL or post a comment on this site....
    Jason
  • 432 Answers
You are just to funny! LOL! You can download the manual here: http://www.frigidaire.com/support/ResultsPage.asp?strModel=FAC107P1A&User=&Search=Search ftp://ftp.electrolux-na.com/ProdInfo_PDF/Edison/220202d019en.pdf After it stops snoring you'll have to get a cat to keep you company.
Posted on Jul 03, 2007
What can i use for snoring or how to stop snoring?
The number one thing that generally helps sleep apnea is to loose weight. Lots of people have good luck with salf water rinses before bed. There is also a jaw sling thing that works pretty well. Here it is: http://stopsnoringrx.com/anti-snoring-chin-straps-do-they-work/
However, if sleep apnea is so severe that you are not sleeping well and always feeling tired, you probably need to go to your doctor. They may prescribe you an apnea machine. http://www.cpap.com/cpap-machines.php
Jan 17, 2017 | Health & Beauty
Have there any solution for stop snoring?
Yes there are many remedies that will help you to stop snoring. First of all snoring can be stopped by changing sleeping habit and eating habit. Overweight is also one of the causes of snoring. There are many cause of snoring and it is really difficult to figure out what cause you snoring so you could get helps you figure out by providing you with sleep centers and doctors who are expert in that field.They can provide you with natural remedies as well as other anti snoring products according to your need. How to Stop Snoring Sleep Apnea and Snoring Remedies SnoreWorld
Mar 12, 2014 | Gund Arnold the Snoring Pig Gift Packs...
How could I stop snoring.Need an urgent solution
Yes there are many remedies that will help you to stop snoring. First of all snoring can be stopped by changing sleeping habit and eating habit. Overweight is also one of the causes of snoring. There are many cause of snoring and it is really difficult to figure out what cause you snoring.So get help from you figure out by providing you with sleep centers and doctors who are expert in that field. They can provide you with natural remedies as well as other anti snoring products according to your need. How to Stop Snoring Sleep Apnea and Snoring Remedies SnoreWorld
Feb 10, 2014 | plaza7.com plastic no anti snore stop...
Have there any medicine to stop snoring in night?
there is a permanent way to stop snoring. It is a surgical method in which doctor tighten or trims extra tissue. There are other surgical methods as well. It isn't recommended much and it might take more than one session.many people visit online sites and find almost permanent solution to their snoring habit. From light to heavy snoring anything can be stopped.You can try this site
Feb 02, 2014 | Omron Healthcare Omron U03 7 Replacement...
I went to my doctor to complain about my snoring and he said he thinks I may have OSAS. What exactly is that?
OSAS stands for obstructive sleep apnea syndrome. This is a condition where you stop breathing during sleep for more than 10 seconds, more than 5 times an hour. Snoring can sometimes be an indication of OSAS which is potentially dangerous, so it's important that your doctor follows up with some tests.
Feb 13, 2013 | Health & Beauty
Can anyone help me choose an anti snoring device? There seem to be so many and it's confusing.
Choosing from the massive range of anti snoring devices can be overwhelming. It really depends whether you are dealing with chronic, mild snoring or other breathing problems. Make sure you get some medical advice before you spend money.
Take a look at this consumer report which gives a good overview of some of the many products out there on the market today;
http://www.stopsnoringconsumerreports.com/anti-snoring-devices-which-should-you-choose/
My son snores really loudly. He sleeps with his mouth open. Is this what's causing the snoring? Would it help if he closed his mouth?
Snoring with your mouth open is the most common way that people snore. It's usually indicative of a problem with the tissues in the throat (ie maybe too loose and therefore causing a blockage in the airways).
You can't make somebody close their mouth when they are sleeping especially if their breathing feels restricted, which is why they are opening their mouth.
Heating & Cooling Logo
2,191 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
