Question about Sparton 1934 6 Volt, Ahoogah, Oogaa, Oogah Horn, Refurbished
WIRING DIAGRAM FOR FORD MODEL A OR T
NEED SCHMATIC FOR WIRING OF FORD MODEL A HORN FROM WINDING FIELDS OUT TO CONNECTOR BD.
My 2004 freestars horn went on & wouldnt turn off until i started the van & hit the horn
The horn wires needs to be inspected.Click the link below and follow the wiring diagram.You just need to follow the wiring shown in diagram and disconnect the wire getting to horn.Then test it with meter and see if your are getting voltage with horn depressed and not depressed.Click the link below for wiring diagram.:-------http://technoanswers.blogspot.in/2012/02/vehicle-wiring-diagram.html
---------Thanks.
Jan 30, 2012 | 2004 Ford Freestar
My 2000 ford ranger horn has only one wire hooked up should it have 2 wires connection. Thanks Wayne .
Hi Wayne,
Some models have single horns, others have two (or more).
Some horns are already earthed, hence may not require the use of an earth wire.
If you have noticed a spare wire/connector coming off the horn harness, this could simply be part of the standard factory horn harness (which was also used for the multiple horn types), making this a redundant connector.
If your horn is working, then I believe the all is in order. If however, your horn does not work, then suspect there is a broken connection.
Cheers,
Aug 27, 2011 | 2000 Ford Ranger SuperCab
What is the fuse diagram for a 1995 Ford Taurus? I do not have a owner's manual.
I recommend going to the Auto Parts store and paying $19-$25 for a detailed 1995 Ford Taurus Chilton's repair book. It will show fuse box schmatics and wiring diagrams a long with everythnig else you need to maintain your car.
Jan 27, 2011 | 1995 Ford Taurus
The horn dose not honk, ford 150, 2005
Did you check the fuse for the horn ?
Next, check the horn connector with a meter ( set to DC volts ) and have someone press the horn button, you should get + DC at the connector.
If not, pull the horn relay, and jumper the normally open contact ( red line in the diagram below )
With this jumpered, and the horn fuse good, the horns should sound. If not, recheck the fuse or could be an issue with the horn connector.
Oct 17, 2010 | 2005 Ford F-150
Admiral dryer timer schmatics
You will need to provide the Model #. You can try this link and they may have the wiring diagram available. Just enter in the model number and see if the diagram comes-up as part of the breakdowns. Good Luck. http://www.reliableparts.com/models/
Sep 24, 2010 | Dryers
Need wiring diagram for a 1997 ford f 150 p/u 4wd
The field wire to the starter has a small eyelet connector that connects to the small terminal on the starter solenoid (sometimes marked "S").
All other wires have a large eyelet connector and they are all connected together with the battery cable to the large terminal on the starter solenoid (sometimes marked "BAT").
Sometimes the field wire to the starter is a push on type connector, and there would only be one obvious terminal on the starter solenoid that it could be connected to.
May 02, 2010 | 1997 Ford F150 Regular Cab
Ownersw manual does not list fuse for horn do
here is a link to the wiring schmatics. The horn circuit is on page 27. http://www.pswired.com/misc/pacaudio/syswire.pdf
Mar 10, 2010 | 1995 Chevrolet Tahoe
I have a 1994 Cavalier, 3.1L V6 engine. I just
check all grounds going from the battery to the block and the body remove the wires and sand the body/block and the silver loop connectors problem should go away
Oct 19, 2009 | 1994 Chevrolet Cavalier
Need to find the horn relay in a 1993 ford mustang gt I tested the horn and all fuses. I don't have a wiring diagram and chiltons doesn't show the horn circuit
94 was a new model freshening and I have 94. may be similar.
Horn Relay and fuse is in fuse box in engine compartment, driver side in front of strut tower.
Horn System The horn system includes:
  • Dual horns (13832) (one high pitched, one low pitched).
  • Horn blow switch (13A875) which grounds the horn relay, which energizes the horns .
Apr 19, 2009 | 1993 Ford Mustang
Sparton 1934 6 Volt, Ahoogah, Oogaa, Oogah Horn, Refurbished Logo
35 people viewed this question
Top Sparton Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Sparton Science and Laboratory Expert? Answer questions, earn points and help others
