Question about Canon imageRUNNER 5000 Copier
Printing too many pages
Imagerunner 5000
From within a program, any program, when selecting more than 2 copies of a file, one gets multiple sets of the number entered. An example, you enter 2 copies and you get 2 sets of 2 = 4 copies or enter 3 copies and you get 3 sets of 3 = 9 copies.
  • phatcher Jan 21, 2009
    This problem is only for (1) person when sending a print job from their PC.
  • 168 Answers
Try this touch add functions key then printer settings one option should be number of copies make sure it is set at 1
Posted on Jan 21, 2009
  • andzulisv Jan 21, 2009
    check the driver they are using to print you canget updated drivers from imagerunner.com support / downloads
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Epson 600 stuck on making 3 copies,no matter if i set it for one copy
Select Basic Print Options After opening your file for printing, open the Print window to select your print options. 1. Open the File menu and select Print. 2. Click the arrow to expand the Print window, if necessary. wf600.1.86.1.jpg 3. Select EPSON WorkForce 600 as the Printer setting. wf600.1.86.2.jpg 4. Select the copies and pages settings for your print job. Note:
If you don't see these settings here, check for them in your application before printing. 5. Select page setup options. Use these options to select the paper size, orientation, and scale. Note:
If you don't see these settings here, check for them in your application before printing. For example, you may be able to open the File menu and select Page Setup. 6. Select any settings that are specific to the application you're using. For example, if you're printing a photo from Preview, you see the application settings shown above.
If you have any doubt in this pls click here
Jul 26, 2011 | Epson WorkForce 600 All-In-One InkJet...
MY printer stopped working from on day to the next...the problem is when I print out a photo from IPhoto or Preview on my IMac OSX10.4.11 it starts with a large margin which doesn't allow for the complete...
Hello
Large photos are printed differently than regular photos.
Photos that have large resolutions or are best when printed in larger sizes are sometimes printed on multiple pages. Printing the photo on two or more pages requires setting up the printing options so that the printer recognizes how the photo should print and which areas to stop printing on each page.
Open the photo in iphoto
Select "File" and scroll down the list until reaching "Print". Click on "Print" and wait for the printing set up options. Some programs require selecting "Set up" or "Print set up" instead of "Print." Make sure the set up options are brought up according to the program.
Select "Time Imageable Table" or similar options in the program. If there is not an option with a similar title, look over the various titles and any pictures that come with the titles and see if the pictures show multiple pages or only a single page. Click on the options that allow printing one photo on multiple pages.
Select overlap options, which give margins so that connecting the pages forms the picture. Overlap around 1/2 inch or so.
Print the photo. The number of pages should match the set up options selected under the imageable table.
Nov 17, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Canon Image Runner 7200 prints twice instead of once. When I ask for two copies I get four copies.
If you are using Windows, you will want to check the drivers of the printer to make sure you are not selected on 2 copies.
Go to Control Panel\Printers and faxes
Right click on the printer driver and select "printing preferences".
Make sure the "Copies" is set to 1.
You can also try a wtest page by going to "properties" and select "print test page".
Mar 25, 2010 | Canon imageRUNNER 7200 Copier
How can it set the printer up so that I have preferences i.e selection or number of copies or certain pages only?
This is done through the print software. Depending upon what program you are using, there may be more than one way to start a print job:
1) Click a print icon within the application - this will usually print with the default settings, (prints entire document, 1 copy)
2) Click the "File" menu, then select "Print..."
This brings up the print job with options for printing, for example number of copies, certain pages, order of printing etc.
If you found this advice helpful, please vote.
Jan 14, 2010 | HP Officejet J3680 Multifunction Printer...
Cannot send a p rint job to pring labels from word to bypass tray with Canon 5000 copier Click on copier properties, click on bypass tray and then ok and print. Will not print fromt he bypass tray Ideas?...
If you can copy from the bypass, you should be able to print from it. It may be a setting in the print driver. Not the one you use through windows but the one installed in the printers folder in control panel. Check that it is not set to draw 1 - it should be on AUTO. Also, the document you are using has print settings of its own - check them as they will overide the tray you select. Select from within your document file - options - printer then look through those settings and anything telling the machine to print to a particular draw will make your job go there instead of where you ask it to.
Jul 09, 2009 | Canon imageRUNNER 5000 Copier
Similar problem with a 6020
use pcl 5c L1 (please note it's very fast driver but only for single set print because this driver have some fault if you select 2 copies for print it print 4 copies so for single set it is the best and for many set try pcl 6 driver)
Jun 15, 2009 | Canon imageRUNNER 5020 Copier
Printing steps for 4x6 size photo paper
Try this :
1) Within your application click on FILE and PRINT
2) Depending on the application in use, you may see either "Printer" or "Format for". Ensure your printer name is selected here instead of "Any Printer".
3) Click the up/down arrows next to COPIES and PAGES to see all the available setting options:
A) COPIES AND PAGES
Allows you to select how many copies you want and if you want to print all pages, selected pages or a specific page.
B) LAYOUT
Adjust the way the image is displayed on the media for multiple page printing.
C) SCHEDULER
Allows options for when to print a job, such as specific time or to hold the jobs, and the priority of the job to be printed for networked machines.
D) PAPER HANDLING
More page options, such as even or odd pages only, and reverse print order.
E)COLORSYNC
Connects to color options managed by the ColorSync Utility.
F) COVER PAGE
Provides the option of including a cover page or not with your prints.
G) PRINT SETTINGS
Select your MEDIA TYPE and INK. You can also create and save CUSTOM SETTINGS through this area.
H) COLOR MANAGEMENT
Adjusts BRIGHTNESS, CONTRAST, SATURATION, and INK balance. Also gives ability to allow COLORSYNC to control all printer colors.
I) EXTENSION SETTINGS
Provides the option for printing on thick paper and envelopes * This option may not be present with all models.
K) SUMMARY
Details settings chosen in other options.
After making the changes appropriate to your set up and print job, click on PRINT.
Aug 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon IR 5000 Printing multiple copies of mutliple copies
Dose it do it when you use it as just a copier? I would have to say that the problem lies with in your network some where. Call your IT person.....
Jul 15, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
106 people viewed this question
old marine
old marine
