Undersranding symbol definitions on the pro-form 9405 exerise bike
What is the symbol rate of 256 QAM?
Without knowing the bit rate, you would not be able to calculate the symbol rate; and without the symbol rate you would not be able to calculate the bit rate.
Based on the below referenced web sites, you can see that the symbol size for 256 QAM will be 8 bits without considering error detection/correction. The QAM value is determined by taking the number of bits/symol and rasing 2 to that given power.
8 bits/symbol => 2^8 => 256 QAM
Simple definition of 256 QAM
256 QAM dictionary definition 256 QAM defined
Comparisons of different QAM to demonstrate bits/symbol to QAM ratio
Comparison of 8 QAM 16 QAM 32 QAM 64 QAM 128 QAM 256 QAM Types
Oct 15, 2014 | Electronics - Others
I need for Pro Form exersize bike For a mamual ?
go to www.iconservice.com find your model free manual on pdf file.
Sep 18, 2014 | Exercise & Fitness
Pro-Form XP Whirlwind 320 Exercise Bike
You may need someone to look at this on the inside. You need a professional.
Oct 28, 2013 | Proform Pro-Form XP Whirlwind 320 Exercise...
Short-circuit?The bike is always on even if the switch is to OFF
Definitely sounds like a short circuit, particularly since you're getting battery voltage at the ground terminal on the switch. With that kind of short, it's very possible your battery may have gotten damaged, or at least drained, while driving.
Jul 16, 2013 | Yamaha MT-03 Motorcycles
Lost instrutions for exercise bike profom 760HR
go please to the next web : www.fitness.manualsonline.com or www. iconservice.com
God bless you
Jul 02, 2012 | Smoothfitness Smooth Fitness 76 HR Pro...
Is passion pro is really good? I mean there is nothing to face any kind of problem in mileage or any type of things
Hero Honda Passion pro is one of the very good bike and nice looking in various colors. ammiraju_d.jpg It definitely give more than 60 km/per liter. Self start will help you more in city traffic. It will give very good beating. And here you have chance to choose either Cast Wheel or Spoke Wheel. Now they launched new look bike with digital meter. Only draw back, it is only 100 CC.
Nov 06, 2010 | 2006 Hero Honda Passion Plus
It will not run 2 110 units at once, with full power. It has only been started twice, to exerise it. Is there a way to to get full power that I'm not doing?
. we found in approximately 2006 389 of this unit has improper wiring behind the control panel. have your unit check out fri-st. buy applying and load and over load test buy a pro. also after running for a shot time what we call a brake in time rune's out of sink. needs to be recalibrated. We have set them to 3645 to 3698 rpms to achieve 60 hz 125 vol /250 vol no load in order to maintain 120\240 full load. we use a gen set test station calibration unit to set all units. the unit is set at factory 3600 rpm 60hz 125 to 130\250 no load. good luck
Oct 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
How to find general anti-derivative Problems in Casio fx-115ES... I get the message syntax error, and also when the anti-derivative is bounded I get my answers in decimal form, i dont want decimal form......
I assume that by anti-derivative you mean the integral. I believe that you can only calculate definite integrals with this calculator. A definite integral requires that you specify the function e.g ln(x), the variable, x, the numerical value of the lower limit, 0.5 and the numerical value of the upper limit , say 2.
Try this: INT(sin(x),x, 0, pi/2)
This calculator can only give numerical values of definite integrals. If you want to perform symbolic calculations, you shoul look towards some other, more sophisticated Casios Casio ClassPad 330, or the TI Voyage200PLT, or the TI89Titanium. etc.
Hope it helps
Aug 28, 2009 | Casio FX-115ES Scientific Calculator
Bike Chain Problems
Something is definitely not right when it does that. Are there any peices of the derailer missing? There should be two tiny gears where the chain forms an "S" as it passes through the gears. Check that they haven't come undone or popped off or that they aren't broken.
Aug 18, 2009 | Cycling
55 people viewed this question
k24674
jasbo
jasbo
