Question about LG WT4801CW White 3.7 Cu.Ft. Large Capacity High Efficiency Top Load Washer with Electronic Control
Wt4801cw disassembly instructions - LG WT4801CW White 3.7 Cu.Ft. Large Capacity High Efficiency Top Load Washer with Electronic Control
How do I increase the water level on my LG washer WT4801CW
The level sensor may be defective and should be replaced.
Oct 08, 2016 | LG Washing Machines
Lg top load washer 1 year old, vibrates violently during spin. Checked an adjusted level, no help.
they have springs and shock absorbers in the machine to help stabilize the load when spinning. since the washer is so new, i would guess one or the other has just come loose. take top off and check. online videos will show you how
Feb 24, 2016 | LG WT4801CW Top Load Washers
Top load LG washer spins but will not agitate
It sounds like it needs a new clutch. Call a service engineer in.
Feb 02, 2016 | LG WT4801CW Top Load Washers
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
Lg wt4801cw no power cant open the lid
Check out this on YouTube. DOA and lid lock stuck locked. You pull up the top of washer and pull little red string to release lock. I was so happy to find this I wanted to share.
Apr 15, 2013 | LG WT4801CW Top Load Washers
LG wt4801cw stopped working with 30 minutes left . I unplugged it and now it won't poer on. Do you think it is the control board?
Lid won't open! Mine too! Wet clothes, waiting for parts, if you remove the sliver back cover, about 16'X16's four Philips screws, look up on the right side of the machine behind the drum, way up there's a solenoid. Mine had a red string! I pulled on it and got my wife to try the lid, it opened! LG says you cannot open it, but that's not true. They just don't want you looking inside the junk machines they sell! Good luck!
Jan 06, 2013 | LG WT4801CW White 3.7 Cu.Ft. Large...
LG WT4801CW HE top load washer poor performance.
I think you will find that hair and lint is much more effectively removed in a dryer.
Mar 23, 2017 | LG WT4801CW 3.7 cu. ft. top load washer
I want to see pcb identification
Follow these links
http://www.celtnet.org.uk/mobile-phone/manufacturer.php?id=11
http://www.celtnet.org.uk/mobile-phone/disassembly-instructions.php?pid=167
http://www.celtnet.org.uk/mobile-phone/disassembly-instructions.php?pid=163
http://www.celtnet.org.uk/mobile-phone/disassembly-instructions.php?pid=164
This link you help more ,
http://gsmsolutionforum.blogspot.com/2010/12/nokia-6300-memory-card-problem-solution.html
Hope this helps
Jan 22, 2011 | Nokia 3310 Cellular Phone
LG WT4801CW White 3.7 Cu.Ft. Large Capacity High Efficiency Top Load Washer with Electronic Control Logo
26 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
