Question about Maytag Atlantis MAV7260B Top Load Washer
MAYTAG TOP LOAD WASHER
NEED TO REPLACE BELT WASHER WON'T TURN OR SPIN
  • 1 more comment
  • SmittyKool Jan 19, 2009
    I have model: PAVT244AWW. The washer stopped spinning. Seems to need a new belt. How do I replace the belt?
    Can you help?
  • bb80577 Feb 04, 2009
    my tube on my maytag performa model # pavt244aww unbalances way to easy and knocks against the side of the walls. how can i fix this problem?
  • Anonymous Mar 24, 2014
    it will not spin out its load and I suspect there is a sock stuck somewhere what can I do?
  • 164 Answers
You don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Posted on Jul 03, 2007
I have model: PAVT244AWW. Can you help?
Posted on Jan 19, 2009
2 Suggested Answers
SOURCE:
BarrettDenCo
  • 1772 Answers
SOURCE: My maytag atlantis top load
Sorry to read about your problem, I hope this helps you out.
you must have a defective transmission. you will need to call a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer spins on delicate only. Won't spin on
Hello, Does it sound like its spinning in regular and just not spinning? If So You may just need to replace the belt. Also this unit the motor pulley would melt and break. Lean the unit back and you can see the belt and pulley. Hope this helps and please dont forget to rate me. Thank You...
Jun 08, 2011 | Maytag Atlantis MAV7551 Top Load Washer
How do I adjust the pump belt on Maytag washer ?
Depends on model.
For top load units with two belts under botton panel, tilt empty washer against a wall to allow access to belts and loosen the 3 pump mounting screws. See page: http://www.applianceaid.com/maywash_belt.html
Jan 07, 2010 | Maytag Atlantis MAV5000
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Washer does not turn or spins
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Nov 07, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Open Questions:
Maytag Atlantis MAV7260B Top Load Washer Logo
475 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
