Question about Maximatic Deluxe Popcorn Trolley Popcorn Maker
On off switch emp 300 - Maximatic Deluxe Popcorn Trolley Popcorn Maker
Where can I get a replacement light bulb for an
Several online retailers sell this bulb, either with or without the bulb housing. There are also several eBay sellers who offer this bulb as part of regular inventory (new bulbs) though I don't have personal experience with any of them.
Search GoogleShopping for the model name and the word "bulb" like this:
http://www.google.com/products?q=EMP-X3+bulb&scoring=p
And you'll see your options.
Note: Be sure to double-check the model of your light box BEFORE you buy a lamp. I'm familiar with Epson's EMP-X3 projector, and I've heard of an EMP-X3 television, but I haven't ever heard of an EMP-X3 light box.
Aug 02, 2010 | Epson (DHV13H010L18) Projector Lamp for...
Connectivity question on EMP-61 Projector
a component switch is what i use, but there are alot better projectors out there for your price range
Apr 03, 2010 | Epson EMP-61 Multimedia Projector
I have an Epson EMP TW10. I have replaced the lamp but it will not illuminate. The temperature warning light flashes red permanently after switch on.
Hi
Can you check the filter for the projector, looks like a screen underneath or on sides, open and clean it up.
Hope this helps
Mar 26, 2010 | Epson EMP-TW10H Multimedia Projector
My Epson EMP-TW20 projector has consistantly started cutting out 20 mins after being turned on, it then switches to stand by and I think the fans go on for about 5 mins. However, if I switch it straight...
clean it out with canned air. the dust keeps in the heat that the projector is trying to expell. you may need to replace the temp sensor, as the constant heat may have weakened the sensor.
Nov 01, 2009 | Epson EMP-TW20 LCD Projector
I need coding with description
The various combinations of these attributes may result in code that looks something like this: sub calcPay(emp) // Calculate pay subroutine if emp.isManager // field reference if emp.isExempt if emp.isPartTime foo_1 else foo_2 end if else // non-exempt if emp.isPartTime foo_3 else foo_4 end if end if else // non-mgr if emp.isExempt if emp.isPartTime foo_5 else foo_6 end if else // non-exempt if emp.isPartTime foo_7 else foo_8 end if end if end if end sub Here we have 8 different "cells" based on all possible combinations of the 3 attributes. (Note that some cells may be error messages for invalid combinations.) Variations of this structure are not uncommon. Thus the question: how does one "fix" it? One approach is to convert every IF block into a separate subroutine. sub calcPay() if emp.isManager doManager() else // non-mgr doNonManager() end if end sub //----------------- sub doManager() if emp.isExempt doMgrExempt() else // non-exempt doMgrNonExempt() end if end sub //----------------- sub doMgrExempt() if emp.isPartTime foo_1 else foo_2 end if end sub //----------------- sub doMgrNonExempt() if emp.isPartTime foo_3 else foo_4 end if end sub // etc.....
Apr 10, 2009 | Computers & Internet
I have an epson emp-52 with a lamp temp falshing red. I replaced the lamo, but it is still flashing. I took it to the local repair and they first said it was the lamp and then the balast. I saw in the...
There is a little safety switch on one of the lids of the lamp cover.
this safety switch was bend but was still giving contact, when the lamp heated up, this switch was opened and the projector came in a safety mode, which turned of the lamp.
Bending this back solved the problem
Jan 05, 2009 | Epson EMP 52 Multimedia Projector
EPSON EMP-S4 PROJECTOR
switch your video source first and then the projector second-confirm that you select video input from menu or from your input button-confirm that your video cable is good ,change it with another good one to confirm that there is no problem in cable.
Feb 12, 2008 | Epson EMP-S3 Multimedia Projector
Maximatic Deluxe Popcorn Trolley Popcorn Maker Logo
Top Maximatic Kitchen Appliances - Others Experts
raysaw
Irene Tulloch
ELECTRICKS
ELECTRICKS
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
