Question about Home
How do I fix my doorbell - Home
    New Friend:
    Problem Solver:
  • 14 Answers
This is a great resource for fixing broken doorbells
http://www.familyhandyman.com/DIY-Projects/Electrical/Electrical-Repair/repair-a-doorbell-fix-a-dead-or-broken-doorbell/View-All
Posted on Jan 10, 2013
Model No. JSJS-204 Doorbell draining batteries fast! About 4 months old. Now on 3rd set of batteries.
It might be your batteries. Are you using Lithium or regular batteries? Often the cheaper batteries will go down FAST!
Consider investing in a new doorbell, or buying a rechargeable battery pack so you're not continuing to replace the batteries but simply recharge them - usually overnight. Battery chargers can be expensive, so try to buy one that charges a varity of the kinds of batteries you use most often.
  • Other "fixes" with doorbells include checking to ensure the batteries are properly seated - ie. press the spring down and make sure the batteries aren't grounding out on another part of the case.
  • Is the temperature in your area cold? Cold will sap a battery FAST - and that's everything from car batteries to flashlight, doorbell, anything that depends on any size of battery.
  • Do you have kids who play with the doorbell? Frequent use will kill the batteries.
  • Do you have a battery level checker to make sure the "fresh" batteries you're putting in are really fresh? Here's a $7.95 battery checker from Amazon. Many packages of batteries also come with checker built into the cardboard container (free!) as well.
Feb 05, 2018 | Home Security
How to fix a doorbell
Depends what sort of doorbell. Wired, battery wire, remote, battery remote.
Make and model may help you get an answer.
Jan 20, 2018 | Home Security
M&S DMC1 door bell error
I'm having the same problem did you find a fix.
May 22, 2012 | M&S Systems M S Systems Dmc1rsa Standard...
I have a IQ America doorbell with 5 chimes and 5 tunes and the bell only plays a sorta gong which cannot even be heard How do I fix this problem so that it plays a chime/tune?
We had a similar problem with a wired doorbell. There is a diode in the doorbell itself that causes the chime to ring fully. If the diode is backwards, you get just a small tone and can only hear the full chime if you hold the button down. If this sounds like your problem, open up the doorbell at the button end (or have an electrician do it) and reverse the diode.
Nov 07, 2011 | Desa International White Wireless Plug In...
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
Jun 21, 2017 | Heath Zenith Designer Series...
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
Home Logo
412 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
