Question about Toshiba Satellite A135-S2276 Notebook
Receiving PXE-E61 media test failure/PXE-M0F exiting intel PXE RO
I read before what the problem is, but how do you fix it, if you are not able to disable the lan bootup. I can boot to floppy and have tried to redo the bios but nothing changes. What can be done?
  • townboy May 11, 2010
    geekman, tks much, but what if you changed the bios to default, but it still does the same thing? I even tied to update to the lastest bios and nothing changed.
  • Toshiba Master
  • 32,281 Answers
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. This fixed my problem with the above error. Nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network.
Its a bios function not a windows function.
Posted on Jan 21, 2009
  • Chris Hingee
    Chris Hingee Jan 21, 2009
    PXE-E61 error can also be a faulty hard disk or a faulty hard disk controller. Take the hard disk out and put it into a USB hard drive adapter and connect it into another computer, if this computer sees it as an external drive and you can open some files then it is OK and the fault is most likely the hard drive controller.The controller is part of the motherboard and near impossible to fix.
    Also check your BIOS settings for the hard drive.
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
When trying to reboot I'm getting this pxe-e61: media failure
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Oct 10, 2006 | Compaq Evo Notebook N200 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
431 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
