Question about Seagate 500GB FreeAgent GoFlex Hard Drive
Goflex 9zf2a2-500 not reading - Seagate 500GB FreeAgent GoFlex Hard Drive
Seagate goflex 500gb not detected giving 3 beeps
See if Testdisk sees the drive and if so try restore or create a boot sector
Nov 21, 2017 | Seagate FreeAgent GoFlex 500 GB USB 3.0...
How connect ext mass storage Seagate FreeAgent GoFlex Net to LAN through router by TCP/IP
Here is the link to the pdf for your Go flex.
http://www.seagate.com/files/staticfiles/support/docs/goflex/goflex-net-user-guide-en-us.pdf
This is an excerpt from the file concerning NOT using the pogoplug...
Accessing GoFlex Net Without Using the Pogoplug Service (Windows)
You can access the drives connected to GoFlex Net without using the Pogoplug Web
interface. Follow these steps to set up local network access.
1. On the Windows taskbar, click Start > Network or right-click My Network Places >
Explore.
An Explorer window opens showing all computers on your network.
2. Locate and then double-click the computer name associated with GoFlex Net.
NOTE: Your GoFlex Net name starts with the letters "FADS" followed by the last six
alphanumeric characters of its MAC address. This 12 digit address, preceded by "MAC:",
is printed on the label on the bottom of GoFlex Net.
You can now access each drive connected to GoFlex Net. Access is regulated by the file
sharing permissions you set using the Pogoplug service.
Hope this helps...
Nov 01, 2012 | Seagate FreeAgentĀ® GoFlex? Black 1TB...
Hdd seagate 2tb suddenly not work i connect and the light flash and my pc and mac dont read the hdd pplease help
Hello OS,
The GoFlex Desk external drive have ample storage capacity and it's easy to upgrade to any interface you need.Pairing the desktop hard drive with a GoFlex USB 3.0 or FireWire800/USB 2.0 adapter to increase your performance by up to 10 times. Works interchangeably between a PC or a Mac® computer.
Please visit the link provided below :
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=214431&NewLang=en
Jun 07, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
How do I get the saved files from my GoFlex on my new computer
You should be able to just plug it in to USB and read them since the harddrive has aleady been set up and used. The new machine should read it just like it will read a thumb drive you've saved files on. This is one of the big reasons why people like these external drives :) You can take them with you and use on another computer.
May 28, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Hi, I bought a Seagate GoFlex a couple of days ago and successfully backed up my Mac at home. However, when I went to use the GoFlex on my PC at university, the PC was not reading the goflex. Thanks.
Did you reformat the FreeAgent drive when you backed up the Mac? If you use Time Machine or other backup software for the Mac, you had to reformat the drive. If you want the PC to read the disc, it must be formatted in a FAT32 or NTFS file system. The Mac OS formats discs in the HFS+ (extended hard drive format) system.
Unfortunately, if you reformat the disc to a Windows compatible format, you will lose your current backup. The drive will be as a large media transfer disc but not for the backup images. This site, http://www.cs.ubc.ca/~pcarbo/macnexstar.html , has information on splitting the hard drive into two partitions, one HFS+ and one FAT32. Then you could have your backup on one part of the GoFlex and still transfer files from the Mac to the PC and vice versa.
I hope this helps.
May 18, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
The Samsung Freeagent GoFlex external hard drive is not recognized by Windows 7 OS. I tried to initialize disk under computer management / storage / disk management and got the cyclic redundancy check...
This is a good read on what this error actually means:
http://www.softwarepatch.com/tips/cyclic-redundancy.html
What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
May 03, 2011 | Seagate FreeAgent GoFlex Pro 500 GB USB 20...
I am looking for a manual for FreeAgent GoFlex Desk USB 3.0. I have no idea how it works. It doesn't need fixing, I need to know how to do various tasks.
Here's a link for all the Seagate FreeAgent GoFlex external hard drives support page: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-support&vgnextoid=884623db95b07210VgnVCM1000001a48090aRCRD
I would suggest finding the quick start guide for your external hard drive and reading that first.
Thanks for using FixYa; please post back if you have any problems and I will help you further.
Apr 09, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Where can I download an instruction manual for a Seagate 500GB FreeAgent GoFlex
You can see the manual at the following URL:
http://www.seagate.com/docs/pdf/datasheet/rg_fa_goflex.pdf
Mar 07, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
Seagate 500GB FreeAgent GoFlex Hard Drive Logo
234 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
