Question about Whirlpool GBD307PDS Electric Double Oven
How to program cavity size on whirlpool oven - Whirlpool GBD307PDS Electric Double Oven
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
Error E# and F1
Hello,the error codes E3 and F1 means Wiring harness cavity size does not match previous stored valued
SOLUTION:The "Cavity Size Select"jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for.
Thanks
Jun 01, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool oven model RDE6030A the bottom element
Unplug stove and remove screws holding element to oven cavity. Remove and take to nearest appliance shop and they will match up for you. Not an expensive repair. Hope this helps.
Feb 02, 2010 | Ovens
When I try to use the oven it read error f-3. It does not heat up Any idea whats wrong? It is a whirlpool model. model-rf364bbdqos\n-fe2401557whirlpool oven with error code-f3
MOST OF THE TIME I FIND A F-3 IS A OVEN SENSOR. IT IS A ROD THAT STICKS OUT FROM THE BACK OF THE OVEN CAVITY ALLWAYS UNPLUG FIRST
Jan 12, 2010 | Whirlpool Ovens
My Whirlpoolis showing F-1 Error of the LCD display? What can I do?
F1 code on your oven means "Electronic control malfunction". Clean contacts and reconnect all wires on the control board. If it does not help - replace oven control board. You'll also need to program the oven cavity size in the new control board. Model number is incomplete, so can't tell the part number, can be either 8301919 or 8301345
Oct 13, 2009 | Whirlpool RBS245PDS Electric Single Oven
How do I use the steam clean self-cleaning oven?
The SteamClean option spot cleans the oven in 20 minutes and is recommended for cleaning light spills on the bottom of the oven cavity. When used routinely, the SteamClean option reduces the need for frequent self-clean cycle use. To use the SteamClean option, pour 12 ounces (1 1/2 cup) of water into the bottom of the oven cavity, close the oven door and push the SteamClean button. At the end of the cycle, consumers wipe out the bottom of the oven, easily removing oven soils. The steam cleaning option is eco-friendly and does not require frequent use of the self-clean cycle, which can create a strong odor. Read this in a post about the new whirlpool ranges
Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My oven beeped and then the display went blank, light nworks when you open door and when push a button it beeps
The power is going out to the control panel. It is easy to replace the whole controller. Be careful of the key pad cable. it will break easily. The part is $225 for the controller and $172 for the key pad. There are 4 resisters that heat up and a zen diode that fails DZ1. U1 also may fail. My RBD306PDB10 works great now. Do pay attention to the cavity size after re-installing the board.
Mar 05, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool GBD307PDS Electric Double Oven Logo
22 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
