Question about Nokia E90 Cell Phone (Unlocked) - Black
On my nokia e 90 vibrating alert is not working any more. I checked, vibrating , feature is on for all calls . Could pease help me?
  • Anonymous Apr 06, 2009
    @Fardinfard
    thnxbut it does not worked for me
    President:
  • 392 Answers
Dear friend, it's not just you, some other users like me has a same problem with vibration of E90.
As I searched and as I found this is a bug about firmware of nokia E90 and I think there's no wayto fix it yet.
But my solution is: charge your cell phone completely or unplug and then plug the battery again. When I do it, I get a good asnwer!
Good luck
Posted on Mar 27, 2009
How to change from vibrate to ring?
Hi there.let me give you a hint.First open Menu >>Profile>>Personalise>>Check the Ringing Tone>>Ringing type should be"RINGING">> and Alert For should be "ALL CALLS".Try this this may help you.Good luck
Apr 18, 2012 | Nokia 6760 slide Cell Phone
My nokia 6303 wont vibrate its turned on but dont work.please help
check out the profile settings and check the currently enabled profile that vibration alert is turned on or not.If alert is on then ur phone's motor or the ******** is damaged, take it to repair center.
Apr 04, 2010 | Nokia 6303 Cell Phone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Nokia 5500 Sports - Vibrating alert does not work
HI friend,first of all relax
go to profiles ->edit profile->edit ringing style-> switch on the vibrating alert.And it should work,or else contact the nearest Nokia care and make it a point that you use only original Nokia bcuz your money is worth a lot of toil:):)
This will surely solve your issue!!!
Thank you for giving me a chance to help you out:):):)
And please vote/rate me so that I can improve myself and be of more help to you:):):)
Prasanth83:):)
May 14, 2009 | Nokia 5500 Sport Cellular Phone
Vibrate alert nokia 3110 not working
I think the ******** in your mobile phone is disconneted or not working. Try opening the phone and see for yourself.
May 06, 2009 | Cell Phones
SMS alert not working
Check the ff:
-You might have turned your "message alert" off or your phones "volume" off or silent.
-"Vibration" alert is off
Try this:
-Turn the "vibration" on or activate.
-Be sure the phone "volume" is not zero, empty or off.
Notify me if it doesn't work, if it did pls rate this solution...tnx
Sep 27, 2008 | Nokia N73 Cellular Phone
Ringer doesnt work Nokia 3120
hi follow these instructions
1 menu
2 settings
3 tones
keypad tones (on)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Mar 21, 2008 | Nokia 3100
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
VIBRATING ALERT DOESNT WORK
Open the unit and clean the contact on the vibra and check the vibra to see if its stil ok. Use an eraser to clean the contact.
Jul 24, 2006 | Nokia 3220
Nokia E90 Cell Phone (Unlocked) - Black Logo
143 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
