Question about Motorola RLN4802A RLN4802 - Remote Mount for CDM1250 CDM1550 Control
Cdm1250 will not power up - Motorola RLN4802A RLN4802 - Remote Mount for CDM1250 CDM1550 Control
Not talking far
Check your antenna set up and connections. Make certain all connections are tight. Have you changed anything about the antenna recently, such as location, or stinger length?
Feb 13, 2014 | Motorola CDM1250 Two Way Radio
What is the difference between GM338 and PRO7100
GM338 is an Asia/Pacific model. Available Lowband, VHF, UHF, in 1-25 or 25-45 watts.
PRO7100 is a Latin American model. Can program in English, Spanish, French and Portuguese. Available in 200 MHz, VHF, UHF, 700 MHz.
These are very similar to the CDM1250 mobile for use in the United States. The PRO7100 and GM338 are not type accepted for use in the United States.
Feb 10, 2014 | Radio Communications
External speaker no function
You have the correct external speaker connected, or a generic?
Some radios require certain external speakers to work properly, and generic speakers aren't always the solution.
Motorola 2-way radios of the model you have, may well come under this bracket.
Other than that, all I can suggest is: join yahoo group specific to your radio Make/Model, and the team there will advise you what's best for your radio, plus you can download manuals, schematics and other goodies for your radio and it's all free.
I hope That this has been of use to you.
Best regards,
Peter
Aug 10, 2012 | Motorola CDM1250 Two Way Radio
I have a motrola cdm 1250 y put the watt meter and tr4ansmit only two atts
Hello Miguel,
My advice is to join yahoo group SPECIFIC to your radio Brand & Model No., the people there will be very helpful, and you can dowload manuals, diagrams and other good gear for your radio(IF AVAILABLE), all this is free.
I hope I have helped you to find your diagrams.
Cheers,
Peter
Jul 21, 2012 | Motorola Cdm1250 Uhf 403-470mhz 40 Watt W/...
Cdm1250 ignition on wire radio stays on
I dont understand your question, but ignition wire wich is conected at pin 10 in the accesory connector must be conected to the ignition, fuse is recomended for security reasons but you can use a 1 amp fuse, this line is just a sense to get the radio on or off folowing the ignition
Jan 07, 2010 | Motorola Radio Communications
Motorola VHF radio GM339
Your radio is equivalent to the US version named the CDM1250 or CDM1550. The instruction manual for these radios is available on CD from most Motorola dealers.
Apr 03, 2008 | Radio Communications
Motorola CDM1250 UHF Radio
Renard, just offhand without see'ing the unit, I'd say that something got sparked wrong in the hookup process. The taletell "puff of smoke" tells me the protection circuit or protector diode got "smoked" in the process. It's more than a fuse now, the protection circuit is blowing the fuse, to stop further damage. I'd say that, at least the protector diode needs changed and to check out for any other damage. Probably need a good tech to visually "check" the unit thruout. Definately needs to have it put on the meters and guages to fix all the damage at one time, something that cannot be done by talking you thru it,,, Mechanic
Feb 08, 2008 | Radio Communications
Motorola RLN4802A RLN4802 - Remote Mount for CDM1250 CDM1550 Control Logo
162 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
