Question about Motorola Mobility H700 Wireless Headset
Motorola H700 will not connect or stay connected
No matter what I do this bluetooth will not stay connected to my LG CU515.
With my old phone,when I opened the bluetooth it automatically connected....Should this work the same way....?
I have gone through all the steps numerous times but nothing makes it work correctly.
Also read a post where it might be loose where it opens and I did what was recommended and that did not work either.
Called AT&T and the rep was....totally unhelpful
  • 25 Answers
Hello, dont be dispaired just keep trying to connect by pulling your mike in and out, some times they need to be worn in, had same problem with my first h-700 and after about 20 0r 30 times moving the mike in and out it took off, some of my seven h-700s paired automatically and some didnt, the secret to putting them in discover mode is with the mike closed press the call button till it turns solid purple and briskly pull the mike down and go thru the pairing process.these are my expieriances, may not be a solution but give er a whirl. good luck m,m.
Posted on Jan 27, 2009
Won't stay connected.
check the batteries on the BT headset
May 15, 2009 | Motorola Mobility H700 Wireless Headset
Connect LG CU515 to Motorola H500 Bluetooth
here is the manual for the lg CU515: http://www.wireless.att.com/support_static_files/manuals/LG_CU515.pdf
however, you should just be able to go to the bluetooth menu, select "search new device" (looking for "Motorola H500"), then press "add" - the passcode should be "0000" (without the quotes)
Feb 03, 2009 | LG CU515 Cellular Phone
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
I can't connect my motorola H 700 to my LG Cu515 phone
Press and hold the phone key when he light turns purple open up the mike par to put it into parribng mode.
Sep 29, 2008 | Motorola Mobility H700 Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Cannot connect my Mototoral bluetooth # 5689448N53 to my LGCU515 cell phone
I called the 800 number on the Motorala bluetooth package the woman told me excaltly how to connect my bluetooth to my cell phone thank you!!
Jul 12, 2008 | Cell Phones
Connection
close the boom hold the oval butting until its purple and then open the boom imediattly
Nov 25, 2007 | Motorola Mobility H700 Wireless Headset
Bluetooth headset
Have you ever successfully paired any bluetooth device to the L7c before. I ask this to help narrow the problem...could be a whole lot of things but more info will help me help you.
Aug 26, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
123 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
