Question about ATI Acer Aspire 5251/5551/nv53a Laptop--amd Motherboard New75 La-5912p Mbptq02001
Charger lights flashing on NV53a Gateway - ATI Acer Aspire 5251/5551/nv53a Laptop--amd Motherboard New75 La-5912p Mbptq02001
Why does the cursor disappears on my gateway nv59c after a minute?
It might be set-up to do so. There is a way of accessing the mouse user options through the control panel.
Jul 03, 2014 | Gateway NV53A NV55C NV59C NV73A Acer...
Gateway ethernet controller driver
Use a USB flash drive on the computer you can access the internet on and save the driver files onto it. Then transfer them to your Gateway NV53A laptop.
How to Save Files to USB Flash Drive
Jun 28, 2014 | Computers & Internet
  1. Plug a USB key into a computer you can access the internet with
  2. Get updated drivers from manufacturers site
  3. When prompted to save download choose the USB drive letter which you should see in My Computer/Computer on your 'desktop' screen.
  4. Save file(s) and them remove the USB key when safe to do so.
  5. Insert USB key into your Gateway NV53A and either run driver installer directly from USB key or copy files onto your Gateway.
How to Save Files Using Thumb Drive eHow
Black screen flash bios
You don't need to access the BIOS to format your laptop. Put the Windows disk in the optical drive and then select format when you reach the correct prompt.
May 06, 2013 | Gateway Computers & Internet
The VGA Port on my Gateway NV53A laptop has come loose. It can still be made to work if I position the vga plug upward at precisely the right angle, but that involves keeping the laptop held still, ot
There should be 2 small nuts holding the connector in place these are also used to secure the external monitor VGA connector to the computer. You can get them from a computer shop.
Apr 12, 2013 | Gateway Nv53a
Delete hardrive on a gateway nv53a
To delete a harddrive you would go into BIOS Setup, and remove.
(Main menu, or Standard BIOS options (setup)
Was there a previous harddrive, you installed a new one, and the old is still showing up, or what is going on?
http://support.gateway.com/s/notebook/2010/gateway/nv/nv53A/NV53Asp2.shtml
My intel indicates press F2 to enter BIOS Setup.
The best method I've found is;
AS SOON AS you press the Power On button, start tapping on the F2 key.
You may hear beeps as you do.
Those are Stuck key Error Code beeps, and it is you that is doing it.
Ignore them.
If you do not know how to navigate in BIOS Setup, or save changes; post back in a Comment.
Totally way off? Post back in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Acer Gateway NV53A36u
Need service manual for gateway NV53A laptop
This manual may be found on the Gateway website.
See their support/downloads section.
Search using your notebook model number.
Take care!
damnor01
Sep 13, 2012 | Gateway NV53A24u Laptop
Problem finding bios battery on gateway nv53a laptop
Hi Maggie,
The battery looks like the image below and should be behind the RAM or the PCI covers.
Hope this helps.Thanks!
Dec 17, 2011 | Gateway Computers & Internet
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
ATI Acer Aspire 5251/5551/nv53a Laptop--amd Motherboard New75 La-5912p Mbptq02001 Logo
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
