Question about Canon Office Equipment & Supplies
Printer won't print
Canon color bubble jet printer .
flashing yellow light
also, holding down "resume' key , will not clean print head
I put the printer in a large green garbage bag , attached a garbage tag , took it to the curb and the problem disappeared. thank you for your interest.
Posted on Jan 22, 2009
Prints color badly won"t stay
Hi w0rtm,
To correct this issue you need to clean the print head. Please follow the steps below.
1. Press the "Power" button to turn the printer on. Wait for the printer to fall silent, indicating it has finished all of its warm up.
2. Load letter size plain paper in the printer's input tray if none is present. Hold down the "Resume" button until the printer's power light flashes once, and then let go of the "Resume" button.
3. Wait for the printer's power light to stop flashing, indicating the printer has finished cleaning the print head. Print a nozzle check sheet by holding down the printer's "Resume" button until the power light flashes twice.
4. Examine the nozzle check printout, looking for missing or broken lines in any of the sections. If you see problems with the printout, run the printer's cleaning program again and then print another nozzle check pattern.
If this does not work, please try these.
1. Turn on the printer.
2. Click the "Start" button in the lower-left corner of your computer's desktop. Click "Control Panel." Choose "Printers and other Hardware." Select "Printers and Faxes."
3. Double-click the "Canon i550" icon. Click "File" in the main menu, scroll down and click "Printing Preferences." Hit the "Maintenance" tab.
4. Click the "Cleaning" button. Select "All colors" to be cleaned and click "Execute."
5. Click the "OK" button.
6. Print a sample page and examine whether the quality has improved.
7. If the quality has not improved, repeat Steps 2 and 3. Click the "Deep Cleaning" button this time. Select "All colors" to be cleaned and click "Execute." Click the "OK" button.
If still encountering the same issue, please uninstall and reinstall the unit's driver.
Hope it helps.
Thank you for using FixYa.
Aug 21, 2011 | Canon BubbleJet i560 InkJet Printer
My printer prints, but colors are all off. There
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
If you have a defective printer head, your power lamp may flash during the service mode key-in, and info printouts may not work. In this case, clearing the waste-ink counter may not fix your problem.
Apr 04, 2010 | Canon i950 InkJet Photo Printer
Canon I850 won't print , it has a green light for about 2 seconds then flashes a yellow light for about 6 seconds
Hi there
This is only a try it may do it but I not know,
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i850)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 19, 2010 | Canon i850 InkJet Photo Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
2. Release RESUME
0 presses - green - Test print (or exit service mode on i960)
Jan 14, 2010 | Canon i850 InkJet Photo Printer
My Canon i850 flashes in a continuous cycle of one green followed by 7 yellow blinks when switched on, and does not print. What is the problem and how can it be solved?
try the following
1. Start with printer OFF
2. Hold down RESUME and then press and hold down POWER Button.
3. Release the RESUME but continue to hold down the power button
4. Press the RESUME twice, then release POWER button.
Now you have put the printer in Service Mode so it will accept Service commands. Here is the list of Service commands;
A. Press the Resume button once = Print Service test print
B. Press the Resume button twice = Print EEprom data sheet
C. Press the Resume button Three = Initialize the EEprom
D. Press the Resume button Four = Clean Waste INk Counter
E. Press the Resume button Five = Change Destination settings
F. Press the Resume button Six = Head Refreshing (Cleaning)
G. Press the Resume buttom Seven, Eight, Nine, = Not used
H. Press the Resume button Ten = Return to selection Menu
Jul 28, 2009 | Canon i850 InkJet Photo Printer
I was printing the other day and each page got lighter and lighter and now it doesn't print anything in black. There's ink in it and I turned off the printer. What else do I need to do to get it to print...
How long has it been since you printer prior to the other day ? If you do not use your printer for some time, the ink will dry out even if it's a new cartridge.
May 01, 2009 | Canon I960 InkJet Photo Printer
Canon S400 lite binks 6 times won't print.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Dec 27, 2008 | Canon S400 InkJet Printer
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
I560
If you are lucky clean the contacts on print head or change the waste ink absorber may solve the problem , if not you need to change the print head , part code:QY6-0064 or QY6-0042, about 38 $ on Ebay.
Here is also the manual reset procedure for I560 (and other Canon printers ):
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function :
Nov 15, 2007 | Canon BubbleJet i560 InkJet Printer
289 people viewed this question
old marine
old marine
