Question about Toshiba DKT3010SD Corded Phone
Toshiba DKT3542F-SD how do I change the extension name on the handset?
How do you send a voice message to a different extension?
  1. During or immediately after playing a message, press 6.
  2. Press 2.
  3. Enter each extension number followed by a #.
  4. Press # again to finish. For example:
    • To forward a message to extensions 201, 202 and 203, key in: 201#202#203##
    • To forward a message to extension 201 only, key in: 201##
To return to the previous menu or to cancel message forwarding:
  1. Press #.
Apr 15, 2015 | Toshiba Dkt3020-sd Digital Telephone With...
How to change employee name on toshiba 3220
Older DK systems are very difficult unless you work with them frequently. Newer CiX systems use the eManager interface.
Aug 12, 2014 | Toshiba DKT-3220-SD Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Trying to change the time on my Toshiba dkt2020-sd phone. I don't know how to do it.
FOR THE TOSHIBA DKT 2020-SD:
From main console phone (lowest extension number i.e. x100) pick up handset2_bing.gif and dial following codes:
For Time: Press "Intercom" and the numbers 652 enter the time in military format HHMMSS (HH=hours in 24hr clock, MM=minutes, SS=seconds) press "Redial".
Mar 15, 2010 | Toshiba DKT-2010 Corded Phone
Trying to change the display name on a DKT
DN just stands for "Directory Number", which is also another name for an extension number. That button should either say EXT______, ot DN______ or Intercom.
So, just push any of those buttons, and dial #621
Nov 03, 2009 | Toshiba DKT3020SD Corded Phone
How do you set the timeand date on a toshiba dkt
Please try this..
  1. From main console phone (lowest extension number i.e. x100) pick up handset and dial following codes:
  2. For Date: 651 YYMMDD Redial ----(YY=year, MM=month, DD=day)
  3. For Time: 652 HHMMSS Redial ----(HH=hours in 24hr clock, MM=minutes, SS=seconds)
  4. For Day of Week: 653 X Redial ----(X=day of week 1=sunday, 2=monday....etc.)
If won't work, try this
From Extension port 00 (usualy station 200)
  1. Lift Handset Dial #652
  2. Enter Correct Time HH MM SS
  3. Press Redial
  4. Replace Handset
Regards,
Jeep Brainy
Aug 10, 2009 | Toshiba DKT-2020-SD telephone
Change name of 1 extn
Without picking up the handset, press program *# 1234. 003. keeping pressing the speaker phone until the extn u want to change is displayed. Note down the jack no.
Then press hold and 004. Then press speaker phone 1 time and enter the jack no of the extension whose name has to be changed. then change the name. After you finish entering the name press autodial.
May 14, 2009 | Lands Phones
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
How do I change the name display on my extensions
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Feb 12, 2009 | Panasonic KX-T7630 Corded Phone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Toshiba DKT3010SD Corded Phone Logo
52 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
