Question about LG WM-2277HW Front Load Washer
How much do LG washer motherboard cost? - LG WM-2277HW Front Load Washer
What can be done to stop the orange steam nozzle/ water circulator on lg front load washer to stop leaking after wash is complete. machine is brand new
If you washer is brand new, call LG service. They will replace affected part at no cost to you under warrranty.
Feb 17, 2015 | LG Washing Machines
Bearing noise in a lg washer
Check your owners manual, some models warranty the rear tub that houses the bearing and the inner spin basket. If not the rear outer tub and the gasket between both tubs will have to be replaced the correct the problem. If out of warranty it may not be cost effective to repair.
Apr 04, 2014 | LG WM2016CW Front Load Washer
Can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG.
you must transform the 60hz to 50hz or 50hz TO 60hz.
God bless you
Sep 30, 2012 | LG WM-1832C Front Load Washer
LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
Dec 04, 2010 | LG WM2455 Front Load Washer
My LG Front load washer is making a terrible, loud sound when it is spinning! SOMETIMES there is also a small trickle of water coming from under the machine. It is not putting up a code yet, so the...
Hi dear.According to your explanation,you washer's drum bearings worn out(GONE)It needs to be replaced but it's a expensive job & complex task.Call service centre for cost of replace,make your decision.I hope that helps.Thanks.
Sep 01, 2010 | LG WM1812C Front Load Washer
My lg front loader washer is not turning on at all, no display either.
The same thing happened with ours. We had to have the circuit board replaced which cost $45 plus the labour and taxes the total was $195. However, the serviceman found another problem with the machine which is what caused the circuit to fry. There's a knocking sound from the rear bearing which will cost us $650 more. Ouch!
Feb 21, 2010 | LG WM-2277HW Front Load Washer
LG RD405 MOTHERBOARD PROB.
Before you decide replacing the motherboard, have you determined the fault in the laptop?
I suggest you attach a monitor to the laptop and power up the monitor then bootup the laptop. This will automatically switch the video data to the external monitor. If you don't get a normal Windows image then you could have a faulty video card or faulty memory.
In a laptop the video card uses part of the main RAM (memory), try re-seating the RAM module/s and see if this corrects the problem.
If not you could have faulty RAM module/s, take them to your friendly computer repair shop and get them to test them for you. If these are OK then you definitely have a faulty video chip problem. This is part of the motherboard and the fix is a replacement motherboard.
Replacing the motherboard may not be a cost effective solution, but it depends upon the age of the laptop and the costs of repair.
If you decide to get a new laptop, you can salvage the hard drive from this laptop and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Nov 29, 2009 | LG X-Note LM50 Notebook
Lg Model DLE7177RM It turns on and the dials
I have this dryer. They said fuse to motherboard, but had to replace entire motherboard. Cost to repair with part and labor approximately $250.00.
Jul 30, 2009 | LG Dryers
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM-2277HW Front Load Washer Logo
140 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
