Question about Aiwa AM-F80 Personal MiniDisc Player
Record = caution! - Aiwa AM-F80 Personal MiniDisc Player
How can I switch the mic input from the built-in mics to XLR input?
on the left side of the unit there is a small switch , , set this switch to MIc , or if using a condenser mic set to phantom-mic this gives the mic power , but I will caution you to watch you units power ind as with that setting you battery will drain down quicker than usuall , you will get best results with balanced mic's as the other types will introduce noise (thumping sound) into the recording also try to keep cord lengths down to less than 15 feet as this will introduce noise into recording as well
Mar 17, 2016 | Tascam DR-40 Portable Digital Recorder
Hi I press record the disc player runs for about 8
Sounds like you are trying to put in too much power. Check that the mains adaptor matches the machine.
Jul 13, 2011 | Aiwa AM-F70 Personal MiniDisc Player
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
I have an LG HR598D Blu ray hdd recorder but am having trouble working out how to program it to record tv shows.
Hit the menu button then go to timer recordings (I think. one menu item is for recording and one is for playing). hit new and enter the stations and times etc. To play back just go to
Another way is to do it through the tv guide but dont bother if the show runs early or late you will miss it.
Another is the one touch recording but it maxes out at 2 hours so not for movies.
One final caution - watch the time. i set it ot manual not auto as it stuffs up daylight saving in Aus.
Have fun!
Nov 24, 2010 | LG Televison & Video
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
Jul 25, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
It doesn't record from instrument input , it records only from the microphone of "apple mac"even if we make all that the manual describes
You likely have not got the driver installed correctely. In Windows type machines OFTEN you must install the software driver BEFORE the device is tied to the computer. It sounds like you are on an Apple machine. Look for cautions regarding connection before software is installed.
Apr 05, 2010 | Lexicon Lambda 4x2x2 USB Audio Interface
Rear differential on a 2004 Mustang gt leaking fluid
this is for 2003 7.5 inch ring gear axle. SECTION 205-02A: Rear Drive Axle/Differential — Ford 7.5-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Drive Pinion Flange and Drive Pinion Seal Special Tool(s) s3b%7eus%7een%7efile=st2026a.gif%7egen%7eref.gif2-Jaw Puller 205-D072 (D97L-4221-A) or equivalent s3b%7eus%7een%7efile=st1257a.gif%7egen%7eref.gifHolding Fixture, Drive Pinion Flange 205-126 (T78P-4851-A) s3b%7eus%7een%7efile=st1862a.gif%7egen%7eref.gifInstaller, Drive Pinion Flange 205-002 (TOOL-4858-E) or equivalent Removal
  1. Raise and support the vehicle.
  1. Remove the rear wheel and tire assemblies.
  1. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Remove the rear brake calipers to prevent drag during the drive pinion bearing preload adjustment. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Do not allow the calipers to hang from the brake hoses. Remove the rear brake caliper and support bracket from the knuckle as an assembly. Wire the caliper and support bracket assembly out of the way.
  2. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Index-mark the driveshaft flange and pinion flange (4851) to maintain initial balance during installation. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: The driveshaft centering socket yoke fits tightly on the pinion flange pilot. Never hammer on the driveshaft or any of its components to disconnect the yoke from the flange. Pry only in the area shown, with a suitable tool, to disconnect the yoke from the flange. Disconnect and position the driveshaft out of the way.
  1. Install an Nm (inch/pound) torque wrench on the nut and record the torque necessary to maintain rotation of the drive pinion gear through several revolutions.
  1. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: After removing the nut, discard it. Use a new nut for installation. Use the special tool to hold the pinion flange while removing the nut.
  1. Index-mark the pinion flange and drive pinion gear stem to maintain initial balance during installation.
  1. Using the special tool, remove the pinion flange.
Installation
  1. Inspect the pinion flange seal journal for rust, nicks, and scratches prior to installing the flange. Polish the seal journal with fine crocus cloth, if necessary.
  1. Lubricate the pinion flange splines.
    • Use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. NOTE: Disregard the index marks if installing a new pinion flange. Position the pinion flange.
  1. Using the special tools, install the pinion flange.
  1. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Do not under any circumstance loosen the nut to reduce preload. If it is necessary to reduce preload, install a new collapsible spacer (4662) and nut. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Remove the special tool while taking preload readings with the Nm (inch/pound) torque wrench. Tighten the nut to set the preload.
    • Rotate the drive pinion occasionally to make sure the differential pinion bearings (4630) (4621) seat correctly. Take frequent differential pinion bearing torque preload readings by rotating the drive pinion with a Nm (inch/pound) torque wrench.
    • If the preload recorded prior to disassembly is lower than the specification for used bearings, then tighten the nut to specification. If the preload recorded prior to disassembly is higher than the specification for used bearings, then tighten the nut to the original reading as recorded.
    • Refer to the torque specification for used differential pinion bearings in the Specifications portion of this section.
  1. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Align the index marks. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Install the driveshaft with new bolts. If new bolts are not available, apply Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 to the threads of the original bolts. s3b%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: The driveshaft centering socket yoke fits tightly on the pinion flange pilot. To make sure that the yoke seats squarely on the flange, tighten the bolts evenly in a cross pattern as shown. Connect the driveshaft. .
  1. Install the rear brake calipers.
  1. Install the rear wheel and tire assemblies.
  1. Lower the vehicle.
May 26, 2009 | 2004 Ford Mustang
Caution message on Aiwa AM-F70
Try another disk if still no go try pressing reset button on bottom of unit.
Oct 07, 2008 | Aiwa AM-F70 Personal MiniDisc Player
Just bought it but threw the box away because it worked right the first time!
Caution - some manufacturers recommend a specific type of CD for recording, otherwise the unit may not record properly. Was the CD a CD-R? CD-RW? 74 minute? 80 minute? See if there are any specific requirements first.
Mar 13, 2008 | Audio Players & Recorders
Aiwa AM-F80 Personal MiniDisc Player Logo
50 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
