Question about Weight Watchers Glass Electronic Scale
Why would my glass scales explode
Glass weighing scales , as i moved them they exploded can you tell me why
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
I have a NOVA Weighing Scale model BGS-1212. I am not able to reset the weighing scale display. Please help
i HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
Oct 14, 2012 | Health & Beauty
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
Feb 19, 2012 | Conair Weight Watchers® WW78 by Glass...
Tells different wieght each time
Does it tell you a different weight each time you weigh yourself in the same few times? Or day by day?
If its consecutive uses that give you different weights, if you're within 0.2kg, I wouldn't be surprised if the scale can't do better.
Otherwise, weigh yourself each day at the same time, and take an average of 3 weighings for the 'best' weighing.
Mar 02, 2011 | Taylor Body Fat Analyzer & Scale, Model...
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
My tempered glass vessel sink exploded. Does this happen often?
No it doesn't and it is not supposed to. They didn't have the temper right and it should not have happened. The manufacturer will tell you that you must have chipped it or hit with something and the water temp made it burst. Don't buy it, Glass is tough, and when done right, does not explode easily. Hope this helps.
Feb 20, 2011 | Elite Clear Green Tempered Glass Sink
Keeps showing err. Thinner scale
Tap the scale twice with your foot so 0.0 appears first, then weigh yourself. If you step on the scale before 0.0 appears, the scale will not function properly.
Sep 26, 2010 | Conair Thinner Scale by TH304 Glass Body...
Inner glass on oven door keeps exploding
i dont think its just yours, ours has exploded in the last 20mins. I cleaned it 2 days ago with mr muscle and put it back together properly.
after googling new world oven smashing loads of people seem to have the same problem too.
Good luck
Feb 21, 2010 | Ovens
I have a WW48 glass scale that just imploded.
I have a seca 345 scales, for 5 years giving only great results. Then, over christmas the scales were left in my new premises that are heated by electric heaters only when somebody is there, working. So for 5 days, there was no heating on, and the scales are now turning on okay, but weighing highly inaccurately. What can i do?
Oct 18, 2009 | Conair Health & Beauty
Weight Watchers Glass Electronic Scale Logo
257 people viewed this question
Top Weight Watchers Health & Beauty Experts
aravind shet
aravind shet
Andrew Taylor
Andrew Taylor
Are you a Weight Watchers Health and Beauty Expert? Answer questions, earn points and help others
