Question about Milwaukee 49 19 0026 Tape Measure 25' In/Metric
What is the diamonds represent at the 19.2" on a tape measure
What is the black diamonds represent at the 19.2" on a tape measure?
Sorry justaskjoe, but the black diamonds are every 19.2''. 16'' centers are represented by a red rectangle. The black diamonds allow you to save one joist or stud every 8'. If you use the black diamonds, you will have 5 equally spaced studs every 8' instead of 6 when using the red rectangles. However, I'm not sure how efficient this is considering any sheets I've seen are marked for 16'' or 24'' centers, so although you could save money by purchasing less joists, you would spend a lot of time marking your boards every 19.2''.
http://www.lowes.com/lowes/lkn?action=howTo&p=Build/TapeMeasure.html
Posted on Sep 21, 2009
  • lar_dog May 08, 2014
    Here is another source since the original one is no longer on the site.http://www.ehow.com/about_5095425_diamon...
  • 10,865 Answers
These diamonds represent 16 inch centers for laying out a stud wall.
Posted on Jan 21, 2009
Watch band width for Mont Blanc Model 7035?
Take a measuring tape or ruler and measure the opening were the ban fits.
Oct 18, 2016 | The Watches
How to rewind a tape measure
You'll need to take the tape casing apart but need special security torx bits to do that (a T-8 and T-9). Once apart (careful, two small springs inside) you can take the tape spool apart and rewind the tape to re-establish tension. Then re-assemble!
May 08, 2014 | Black & Decker Auto Tape Measure
NO AUTO MOVEMENT USING SWITCH ? ?
1. Pull the tape out about 12-18 inches.
2. simultaneously pull the slider switch on the bottom and the switch on the top.
May 27, 2013 | Black & Decker Auto Tape Measure
What indicates the black arrow mark in 16inches,32inches,64inches in steel measuring tape
Typical framing is laid out on 16 inch centers. Example: the studs in a framed wall are 16 inches apart which gives the required strength and allows drywall to break at a stud when it is installed. Drywall sheets are 8 foot or 12 foot, if the framing is on 16 inch centers then the drywall will end at a stud. The tape measure is highlighted at multiples of 16 inches to make it easy to mark the studs when laying out the framing.
Jan 17, 2011 | Peachtree Woodworking 12' LEFT READING...
I need toconvert feet and inches to metric
There are many available on line, or as downloads .
Here's an example.:
http://www.onlineconversion.com/length_common.htm
Apr 23, 2010 | Milwaukee 49 19 0026 Tape Measure 25'...
How to fix a stanley power-lock 25 ft measuring tape
Take the four corner screws out and the last center (short screw out). Split the shells in two pieces. Seperate the yellow or measureing tape from the black spindle tape. The spindle tape holds or attaches the measurement tap to the spindle. I have only seen a plastic spindle and this tutorial only applies to the plastic one. Take the spindle out and set the half casings on their backs, so you can see the cavity of the shells. The black spindle tape will be preformed to only wrap one way. Go ahead and attach the yello measuring tape to the black spindle tape. Pay close attention which side of the yellow tape is facing up or in our intended direction which is towards the center of the spindle. This way when you pull the tape out it is facing up for the person can see the measure marks. Wrap the tape tightly. If the tabs are broke and there's no way to secure the Yellow to the black, use two strips of Duct Tape and adhere the sections together. Do not use too much tape, since the clearance inside the spindle is tight. Once you wrap the tape inside, put a temporary piece of tape to secure the yellow and keep it from unraveling again. Next take a 1" wood screw and a battery powered drill and insert the screw into the center of the plastic spindle. Slowly tap the screw until it catches, do not drill the screw all the way in, only enough to catch in the plastic. Once the screw is partly into the plastic place the spindle into one of the half shells. The reason for the drill and screw is to return the tension back to the internal spring. Whichever side you placed the screw into you need to be sure to apply a clockwise turn. Keep the hex head of the drill so to not release the tension. At the same time place the spindle in the half shell and lock its square center piece into the shell. Now you can remove the screw from the center, then remove the tape holding the yellow meauring tape down, Still holding the measuring tape so it wont unravel, begin placing the last half shell on. Obviously you need to line everything up so the tape slides freely through its opening. Align the tape slide stop, which rests between the two shell halves. Replace the screws and remember the short one goes in the middle and holds down the belt clip.
Frank
Jan 03, 2009 | Stanley 30-305 HI VIS MEASURING TAPE
Wiper size
Just take a tape measure and measure the length. 18/19/20 inches. Thats all you need to know.
Dec 25, 2008 | 2005 Dodge Caravan
815c microtek
At reboot the screen would flash on and off, finally settling on.Good resolution...normal,
This worsened and finally a black screen.
I measured the ps output, unloaded, and it measures 19 volts...with a little pulsation.Is there a repair manual available on site?
Feb 17, 2008 | Gateway FPD2275W LCD Monitor
Milwaukee 49 19 0026 Tape Measure 25' In/Metric Logo
428 people viewed this question
Top Milwaukee Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Milwaukee Measuring Tool and Sensor Expert? Answer questions, earn points and help others
