Question about Haier HSB03 Compact Refrigerator
I punctured the freezer part and freon is coming out.
Can it be fixed?
    Genius:
  • 2,920 Answers
No once you bamage it it damaged and cant be repaired
Posted on Jan 21, 2009
Mcbr360 won't get cold at all hear as it come on and then click off I was busting up the ice in the freezer part and I hit something for liquid to spray out of somewhere needhelp ihave a small baby
oh oh seems like you punctured the freon line and now ur compressor will be out of freon and you will need to also replace the part you punctured, the line that is?
that liquid is what keeps ur frige cold!
Dec 18, 2016 | Refrigerators
Punctured inside bottom of chest freezer, now it wont work. how can it be fixed?
Sorry, but you punctures a refrigerant line and the system lost the freon...
To fix this the bottom would need to be cut out of the freezer and then the lines fixed and the system recharged...
Considering the cost of a new freezer... you will be better off to replace the freezer rather then doing that much work to it..
heatman101
Mar 12, 2011 | Refrigerators
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
I punctured a hole in the freezer part will it still work?
UUUUUUUgh....not sure....
if you punctured the part that has the freon zig zagging through it and allowed the freon gas to escape then...nope...it will no longer work and it may cost quite a bit to get it repaired.....but...if you are lucky you may have only punctured the covering and not got into the part with the freon...turn it on and see how lucky you are.
Aug 21, 2009 | GE Refrigerators
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
Freezer puncture.  I punctured the liner to the freezer, creating a slight hole that emitted a vapor (presumably freon).  Must I repair it?  How do I repair it?
The freezer coil where you punctured is made of aluminum and there's not cheap way to fix it , but if the refrigerator is in good conditions you can replace the coil or get somebody to do it ( it is an expensive job).
Aug 15, 2009 | Whirlpool Refrigerators
Puncture freon line in freezer section of refrigerator. Is there a fix
epoxy for aluminum can be used with some success on a puncture in a low pressure system. The problem is not so much patching it as being able to evacuate the moisture and air out before charging. Do you have a vacuum pump? Do you have refrigeration guages and hoses? Is it a new
refrigerator 134a or old r-12? Can you weigh the charge in?
Jul 28, 2009 | Refrigerators
Punctured freon line in freezer
Please don't rate me down for this answer, but I'll be honest with you. No, you can not fix it yourself. The entire evaporator would have to be replaced by a service tech who has a refrigerant certification and the proper tools to do it. It would be prohibitively expensive. It's time to buy a replacement.
Jun 28, 2009 | Frigidaire Freezers
Punctured freezer
You should contact a local welding shop to fix the leak. The tubing is made from aluminum and can be hard to solder for someone who doesn't do it all the time. After that you need an appliance repairman to pit more freon in it. I guess the question is...how old is your freezer? More than 6 years old? Anything older than that, you may just want to get a new one.
Mar 20, 2008 | Sanyo SR-2410 Compact Refrigerator
Haier HSB03 Compact Refrigerator Logo
210 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
