Question about Car Audio & Video
I need to take the back off a navman s70
Ts 10 months old and cant find receipt to send back. the screen is blank when switched 'on' if i press the back of the unit it comes on,the take fingers off the back the screen goes 'blank' again.if i could take the back off it i could fix whats lose-but there is no screws or visible way into it!!
Im surprised noone has answered this considering navmans track record for producing waste products. I say this,as i have 5 sat useless,due to being 2nd owner,so uncovered by warranty,in some cases,units being less than 1yr old,so i have had a look myself. Ok. Here goes. hold the unit screen towards sky,base facing you. You will see 2 screws,one either side. These hold the side covers in position. Remove these,and if you have strong nails,insert finger nail between side cover and back,start at bottom and pop the bottom lug then the top. It should be held the same on other side of side cover. repeat this on other side of unit. The side covers should now be off and exposing back cover side edges now. Take your finger nail and insert between back cover and base at one corner,it should pop open slightly,repeat on opposite corner. This is from memory. your cover should now lift off. Try the screen ribbon where it joins the board for connection first,there is a tiny black lift up ribbon lock to lift up then make sure ribbon is pushed firmly home,maybe even clean the connectors. The rest is in your hands if this does not work. Good luck.
Posted on Dec 03, 2009
Navman problem
WHY is it suddenly, overnight, my Navman EZY 45 has gone from working perfectly to the touch screen hardly working at all? All the buttons have moved ie: You CAN'T touch on the button you want, you need to touch either the one above or below it. As for the Accept and address buttons, well that's just not happening, back = Q and so on.
I have formatted, reloaded maps, done everything Navman has suggested. Is this a Hardware issue? If so, a rarely used 15 month old unit will be going in the bin and I will compare other brands.
Any help appreciated as I love this small but great unit.
Cheers
Jan 02, 2014 | GPS
I cant get past the safety agreement it looks like its loading then it goes back to the safety agreement.
Your problem is in the firware. If you can, try to update your firware; if not the unit will need service.
Jun 25, 2011 | Navman S70 4.3 in. Car GPS Receiver
I need a copy of the original CD which came with my Navman S70 (I've misplaced it)....can I download from anywhere?
Unfortunately, Navman provides their proprietary maps data on the CD that originally came with your Navman S70, so it is not available online to download legally.
You should contact their support team. Contact info can be found at the following address:http://www.navman.com/in-car/europe/uk/Customer-Support/
They should be able to direct you to a secure link for download or send you a new physical CD. Proof of purchase may be required, but you should not have any issues if you explain your situation to the Navman representative.
Mar 14, 2011 | Navman S70 Car GPS Receiver
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Nov 02, 2010 | GPS
I get "fatal application error" program:gwes.ewe Exception:0xC0000005 Address: 00023174 Its a navman S70 3D
I have the same problem started this week.Phone them up, got through almost straight away which made a nice change.But the news was not good must send it back to them. If the guarantee has run out ( 3years ) it will cost £80 to have fixed
Sep 07, 2010 | Navman S70 Car GPS Receiver
My iphone has a white screen, no matter what i tried
This is a condition that Apple is very aware of and if you take your iPhone to an Apple store they will replace it.
Make sure you take your receipt with you.
Other than that, I have not heard exactly what causes it, but i presume it to be a bad batch of LCDs or another critical part causing it.
Mar 18, 2009 | Apple iPhone 3G
Screen blank
Do you have the Lens cap off ? Just asking.
Dec 27, 2008 | Kodak Easyshare C813 Digital Camera
Navman icn 520
There should be a battery On/Off switch on the back. Have you tried turning it off, leaving it for 10 seconds then turning it back on?
Also, there should be a reset button either on the top or on the back. Hope this helps and solves your problem.
Regards
Matt
Sep 08, 2007 | Navman iCN 520 GPS Receiver
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
