Question about Garmin nuvi 200W GPS Receiver
Without plugged in my garmin nuvi 200 will not work
My new garmine nuvi 200 only works when plugged in. the light on the charging cord "from the cigerette lighter to the nuvi" stays on even when vehicle is shutoff. if i have the nuvi plugged in and shutoff, it states that the battery is chargining and i have had it charging for well over 4 hours. i Also have no battery symbol on the screen to say if it is charging or not when turned on. i have tried to turn my nuvi on multiple times while not plugged in and i read the instructions on the switch so i believe im doing it correctly. what could the problem be?
  • 1 more comment
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    It could be a defective battery. The way to test this is to plug the unit into the charger to turn it on and let it go to the main menu. If you then pull the rear mini-USB cable and the unit goes dead, then yes it could be the battery.
    I still recommend calling Garmin and letting them resolve the problem for you.
  • SHARCNET-USA
    and btw, your repost included all of the things I suggested for you to try first before calling Garmin.
  • SHARCNET-USA
    As I told you, if the switch is defective, it won't turn on. Reading instructions in the manual on how the switch is supoposed to work won't help you if the switch is bad. I repair these units, so I believe I have a fair amount of knowledge on the subject. I have seen this problem before.
    Again, if the unit is new and under warranty, why are you not calling Garmin for assistance? Why keep reposting the same question over and over?
  • 19,396 Answers
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 13, 2009
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
May 29, 2010 | Garmin nuvi 260W GPS Receiver
Can not find a USB slot in my Garmin Nuvi 200
I can help you update your Garmin Nuvi 200.
Here is a picture of where the USB cord plugs into your nuvi:
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 21, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 200 worked fine the first 3 times
Connect your GPS to your computer with the USB cable and this will charge the GPS internal battery. Of course your computer will have to be on during the charging process. After a few hours turn on your GPS and see if it now works. If it now works then go to http://www.garmin.com and register the GPS. While you are on line also download the latest USB drivers for your computer and install them. When you reboot your GPS should be properly connected to the computer for Operating system downloads etc.
Apr 07, 2009 | Garmin nuvi 200W GPS
Id the Garmin Nuvi 200 supposed to function when plugged in?
Are you using the factory supplied Power cord or a standard Sony-type plug?
Mar 01, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 200 -- won't power up after plugging into USB & Computer
Found out from Garmin Tech services how to reset the NUVI. Good to go.
Thanks.
Aug 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
My Garmin nuvi 200 stoped working so I went to get new batteries for the cord. They tried to replace them but the Garmin still did not work. They sold me a universal cord with a plug that goes with the...
I had the same problem with my Nuvi 760 turning itself off right after the "Loading Maps..." screen but I found the answer in the Q&A section on Garmin's website.  It's actually very simple and you'll kick yourself...  Charge it up all the way!  It does that when the battery is really low.
Apr 16, 2008 | GPS
Garmin nuvi 200W GPS Receiver Logo
915 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
