Question about Whirlpool GEW9250 Electric Dryer
My dry will not heat up
I have a dty and it was woeking and when i brought to my new place it now will not heat up. I jhave power on all three hook up at the wall and all the dryer dose is spin. No heat.
  • Anonymous Jan 24, 2009
    I have the same problem. I'm trying to check it out today though.
  • Anonymous Feb 14, 2009
    Same thing happened to me. The dryer is 2 years old and worked great. Then I moved and it would not work. First it would come on but not heat and now won't even come on.
    Novelist:
  • 101 Answers
To go off of what the last person said in more detail is that your thermal fuse is probably burnt out. On electric dryers if this goes bad then your heating element won't stay on for more then a second or two. It is located on the inside where your lint screen goes. Open up the front panel and you should see it as long as it's not hidden. There is a wire diagram located behind the backing of the control panel that will help you find this. It's a cheap part running around only about 15 dollars or so at any appliance repair shop. If you have any other question let me know. Good luck.
Posted on Jan 22, 2009
  • 54 Answers
Again, on checking power.. make sure you have 240v.. if you do, then your fuse in series with the heating element is blown..or bad heat selector switch.. one more burnt wires... good luck
Posted on Jan 21, 2009
Indesit iwde7168 fault code f01 on drying
Indesit F01 is a board/motor fault, as it is happening on dry I would suggest looking at the board again ensuring there are no other blown solders or indeed the repaired solder connecting to another
Apr 07, 2014 | Indesit IWDE7168 Washer Dryer - White
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
We have brought home two new roper dryers now because neither one of them heats up. we hooked up a brand new 3 prong plug to the new dryers and plugged them into the existing 220 outlet that our old dryer...
You need to double check that your wiring it up correctly at the junction block on the machine. if thats correct. Most likley is that you actually only have 110 volts going to the machine it will run fine but will not HEAT. check voltage at plug or where its wired into back of unit you should have 110 volts on two out of three with the third being ground if you dont you have a bad outlet or breaker in elec.panel
Aug 08, 2010 | Roper REX4634KQ Electric Dryer
Bosch SHU4302UC/UO6 runs three hours.
Maybe wash temperature. The machine may be trying to heat the wash water to a preset temp and it is taking an extended time to get there. Maybe a faulty temperature probe or a bad element?
I know you will ask how this is possible when you have a final temp of 120 but that sound like a drying cycle temperature to me; not a wash temp.
I would leave the thermometer in through the cycle and you will probably find it will slowly get hotter in wash cycle and finally switch after a certain temp has been obtained.
Oct 05, 2017 | Bosch Dishwashers
Can't read Kingston DTI/4 GB flash drive
you have to see in witch format is the stick mostly is FAT32 but normaly you dont need to format just when is some video on it,from my experience reinstal the drivers and i mean all.
Nov 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
New GE Dryer Not Heating
Sounds like the HEATER COIL is bad or not connected properly on the inside. I would call the place where you purchased and exchange it ASAP.
May 29, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
GE QuietPower 2 has three lights flashing, and won't work
Its the reset cycle... give it a few minutes, and it will be ready to go..
Apr 20, 2009 | Dishwashers
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
Whirlpool GEW9250 Electric Dryer Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
