Question about POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer
Srp350 won't cut paper - POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer
Hi, this printer has stopped cutting automatically. It will cut doing the print test but then will not when info is sent to it?
It sounds like that the thermal printer is not set as the default printer, in printer settings set the thermal printer as the default printer & then print something if the auto cut works then problem solved other wise it could be a problem with the printer or a major bug in the software.
Jun 15, 2015 | BIXOLON SRP350 Thermal Receipt Printer USB...
On the printer the "paper" light turns on regardless of how big the roll of thermal paper in it is. If we open the lid then close it this will occasionally fix the problem temporarily. I have tried to
Take the paper roll out and on the left side down the bottom you will see something that looks like a small light. That is the paper low sensor. Clean the dust out of that with a microfibre cloth. Also, the lever on the left side where the paper goes in adjusts the sensitivity - try moving that up or down.
Dec 23, 2013 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Need for driver
Your printer sounds like it might be a bixolon srp-350 badged as a samsung. I dont know if there are android drivers for SRP350. There is an android sdk for SRP350ii. Anyway this is the site where you will find them if they exist - http://www.bixolon.com/html/en/download/download_product.xhtml?prod_id=3
May 30, 2013 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Circular saw won't start after having cut pavers
You fried the motor and most of the time it isn't worth repairing, since the parts will cost you more that a replacement saw.
If you are going to continue to cut pavers, suggest you either take it very slow and cut 1 or .5 paver and then let it cool down. But a water cooled tile saw would be better.
Jun 24, 2011 | Saws
Royal sc120 shredder wont run.. Paper jammed in head and cannot remove it--no reverse or forward will work.
This is the most common problem..."too much paper".
If it won't go in either direction the only option is to open the cutting head of the machine(after unplugging) and to manually try to turn the gears to un-clog the paper.
Once you have cleared the paper from the cutting blades see if it still turns...see if any plastic gears have been damaged. Plug it back in and see if it runs...if it dosn't you may have blown the PCB in which case you should contact Royal at 1-800-524-0799 regarding replacement parts.
Jun 14, 2011 | Office Equipment & Supplies
Computer dsplays an out of paper error. Printer functions perfect on another computer. Why?
You'll need to provide more info. Where in the computer does it display out of paper error? Is it in the printer driver? or from your software/application? From what i understand this printer's windows driver cannot provide paper out status. Only its OPOS driver can. If you are using the OPOS driver, use the check health option to make sure it prints ok.
Mar 03, 2010 | POS X BIXOLON Samsung Kps SRP350 Thermal...
My bixolon samsung srp 350plus printer will not feed paper when i go to run the test on it it just cuts the top of the paper then paper out light comes on any ideas?
Try to push just the FEED button. if it doesnt feed, call their service center. hope it is in warranty still.
Problem could have happened with a power surge
Jan 11, 2010 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Paper feed
Hi Fieldridle, Im guessing you are connected to the cash register via serial, if so I'd try checking all the serial settings on both the printer and register so they match one another. Next, check that the register is sending the right type of emulation or printer language.
Nov 17, 2008 | Samsung SRP 350 Thermal Printer
Sharing srp350 network printer on win98 to winxp
You are correct with the conflict, although, it's a difference in drivers, i think what has happened is when you share a printer with xp, it installs the driver from the pc with the driver and printer attached, and as it is attached to a win98 pc, the full functions are probably unavailable,unlike an xp local driver.
Mar 06, 2007 | Samsung SRP 350 Thermal Printer
POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer Logo
75 people viewed this question
Top POS X Office Equipment & Supplies Experts
jasbo
jasbo
Are you a POS X Office Equipment and Supply Expert? Answer questions, earn points and help others
