Question about Jensen 143307 Remote Control
Need code for Electrohome EH8022B/EH8041SB
This is a fairly inexpensive TV and the romote stoped working.
This Jensen remote shows Electrohome on the code list. I went through all the codes 3 times and it flashed 4 times and shut off, not finding my code. Any suggestions? This is the second remote I have purchased.
  • roystew Feb 18, 2009
    The sentence after the clarification request posted Feb 18 seems strange. It is not from me.
    I returned the Jensen remote and ordered one from Electrohome. It didn't work either! The problem was in the TV! I took the TV apart and cleaned it. Now both remotes are working fine. Thanks for asking.
  • scf_lc May 11, 2010
    this is a bunch of ****! run AROUND & NIT GETTING A ANSWER
5 Suggested Answers
josh1856
  • 105 Answers
SOURCE: Jensen JER321 3-Device Universal Remote
coding:
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Posted on Jan 26, 2008
josh1856
  • 105 Answers
Code List:
http://remotefinder.rca.com/
Posted on Feb 01, 2008
SOURCE: need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Posted on Apr 05, 2008
SOURCE: remote control code
If you have a Jensen JR500 remote, your codes for a Magnavox TV are: 0054, 1254,0030,0179
Posted on Oct 09, 2008
VOTIT
  • 2071 Answers
SOURCE: HELP!!
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Sorry the manual was not the correct one for this remote. I thought it would provide simular codes to your product.
Here is some helpful information I found:
Without the code on JER-323:
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it help you;
Regards,
VOTIT
Posted on Oct 10, 2008
Sony, RM-V210. need code for Electrohome TV.
This remote control have no setup codes to Electrohome TV. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. View the site in 'Mosaic'. It will make search easy. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability.
Jan 03, 2014 | Televison & Video
HELP!!
JVC DVD 0558, 0623
Hope it help you;
Regards,
VOTIT
Sep 19, 2008 | Jensen 143307 Remote Control
Jensen universal JER323
Sorry but to my understanding there are no universal remote codes in existence for combos. Call an electronics repair shop. Give them the make and model number of your combo. They will be able to order you a new remote for your brand and model. If it is not too old they should be able to get one for you. I got one and it was only $21.00. Well worth it cannot use half of the features without proper remote... Good Luck!
Feb 25, 2008 | Jensen JER-323 Remote Control
Codes
www.remotecodelist.com ........................................T.
Feb 23, 2008 | Jensen JR500 Remote Control
TV code
0381 is one code used for electrohome televisions
Dec 04, 2007 | Motorola Mobility DRC800 Universal Remote...
ASAP
From the website:
http://www.hifi-remote.com/ofa/devices-tv.shtml
0381
If that does not work: try this website:
http://www.bobvila.com/wwwboard/messages/241089.html
They list codes: 006, 011, 014, 027, 038, 061, 068
Hope this helps you.
Mike
Nov 07, 2007 | Jensen 143307 Remote Control
In need of tv codes for ge romote control
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
That is it. It works for me.
Oct 22, 2007 | GE JASRM24912 Remote Control
Jensen 143307 Remote Control Logo
227 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
