Question about Husqvarna Garden
Drive belt on modle 96025000201
Modle 96025000201
Auger will not engage...modle 536.886220
Is you drive belt broken or slipped off the pulleys?
Or has the shear pin in the pulley or auger its self broken?
Feb 11, 2015 | Garden
HOW DO I REPLACE BELTS AFTER THEY CAME OFF?
after a belt has fallen off it will need to be replaced. belts usually just don't fall off. WITH THE ENGINE TURNED OFF! belt removed check the pulleyes and idlers a possible bearing failure or maybe a quill (the blade mounting tower) has a broken mounting point. A good website for ya mtdparts.com
Apr 16, 2014 | Yard Man Garden
Huskee LT 4200 modle 13aj771g031 how do I get the small rear drive belt to go on the pully
Set the brake/clutch. This will disengage the linkage that tensions the main drive belt, allowing you to put it on the pulley.
I hope this is helpful.
Aug 16, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
As I was cleaning my crosley dryer modle cde600w I let the drive belt idler arm relax and the spring came off.Now how do you put it back in place?Can you HELP!!! Thank you.
The idler arm attaches to the base, and the spring attaches to the arm, and then the frame. You'll pull the arm past the belt, and then relax your tension, and transferring the tension to the belt.
--W/D--
Feb 06, 2011 | Crosley CDE6000 Electric Dryer
Altenator belt popped off is not broken 3.0 grand plymoth voger
this is a common problem with dodge, crysler, and plymounth modles with 6 cylinder engines the alignment is slightly off of the pulleys
dodge had this in their service bulletins years ago and but didn't bother to tell anyone about it. you'll need either a replacement idler pulley wich should come with a washer that fixes the alignment or you'll need to purchace a belt kit that replaces the tentioner pully idler pully and has a new double sided ribbed belt.
amazon sells it for about $100. US
http://www.amazon.com/Gates-38379K-Serpentine-Drive-Component/dp/B000NBKI7Q
or try any auto parts store or garage for the kit Gates 38379K Serpentine Belt Drive Component Kit
Jun 06, 2010 | 1996 Plymouth Grand Voyager
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
What size A/C belt does a Mazda 3 use?
It is Unusual to have a Belt "Size" As the Belt Size is determined by the Application, Why a Parts store Cant Get this Info By Use of > Year-Make-Modle-Engine Size is VERY Unusual. Try Another Parts Store, or try this Info.
NOTE: You Did Not Say Engine SIZE so this is for the 2.3L Engine
This Info is for the " 2.3L " Engine
Parts Information Part OEM Part Price Drive Belt Serpentine Belt Manual Trans L373159099U $26.99 Notes Auto Trans L37215909A9U $26.99 Notes AC Belt LF5015908 $19.95 Notes Labor Skill
Level
Mfg.
Warranty
Standard Drive Belt Replace AC Belt C 0.0 0.5 Notes Serpentine Belt C 0.4 0.6 Notes
Jul 21, 2009 | 2005 Mazda 3
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
Garden Logo
22 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
