Question about Ricoh Aficio 3025P Black and White Copier
Ricoh aficio 3025 copies out of alignment
Whether you load the item to be copied from the top feeder or the copying surface, copies are cut off at top. Is there a way to reset this.
  • xtrancey Jan 31, 2012
    I have the same problem, but the copies and printing are cut off at the bottom of the page. I'll try this solution, i hope it will work.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Check the paper size dials (green dials) of the paper trays that are set to match the orientation of the paper loaded in the tray.
On the touch panel display, select Auto paper select icon and retry.
If the dials are correct and the problem still there, please then try to print the counter printout from the User tools (yellow) button or send a print from your computer.
If still with the copies being cut off, please check for toner spillage between the toner unit and Photoconductor unit.
Open the front cover, pull out these units and clean toner spill.
Clean also the laser shield glass. There is a small cover below the toner supply unit, unscrew 1 screw. Pull out the small glass very careful and straight ahead, pay attention not to break it.
Retry copying and printing.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
Half copies
could be black developer unit or pcu / try printing something from doc feeder or platen glass in each single color and see if you have same problem. If other color prints find then will narrow down to items above
Aug 29, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Says load paper when there is paper already loaded
That has happened to us if we lay a small item to copy on the glass, so we would lay a 8 1/2 x 11 sheet over it and it would work.
Feb 05, 2014 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio 3025 Copier LCD Touch Screen gets hang after calibration
You need to replace the screen to fix your problem. But if this machine is the model I think it is you need a whole new machine.
Jul 23, 2017 | Ricoh Office Equipment & Supplies
Why does my Ricoh Aficio 2035e copier produce copies with dark lines across copies?
Make a copy from the glass by laying your original on the glass under the feeder and see if the lines go away. If they do then you need to clean the small strip of glass that is just to the left of the large glass. If you still get the lines then most likely the cause is a bad drum cleaning blade or possibly both the drum blade and the drum itself. If this is the case then you should be able to open the right side door and look closely at the green colored cylinder, which is the drum, and see if you see any wear lines or black lines on the drum surface. If you do then there is your cause. The drum should always be clean and shiny with no toner, lines or wear "grooves" in the surface.
The lines you are experianceing should be caused by one of these 2 problems.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 30, 2010 | Ricoh Aficio 2035 Copier
My ricoh aficio 3025 copier has the capabilities to scan, print & fax but it only copies. Can we add those modules?
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Jul 09, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Jan 27, 2010 | Ricoh Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
AFICIO 551 BLACK AND WHITE
Which feeder? Is it in the document feeder or the paper tray?
Could need a pm to replace the drum, cleaning blade, and possibly developer to get rid of the dirty copy and/or the scanner section should be cleaned as well by cleaning the glass as well as the mirrors underneath the glass.
Dec 10, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 ARDF is not duplexing, why?
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Sep 30, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 3025P Black and White Copier Logo
285 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
