Question about Yamaha RX-V671 7.1 Home Theater Receiver Black
Receiver indicates decoder off? - Yamaha RX-V671 7.1 Home Theater Receiver Black
Auto format decode means?
HI,
There are so many audo formats like Dolby Digital Decoding, Dolby Digital EX Decoding, Dolby Pro Logic Decoding, Dolby Pro Logic II, Dolby Pro Logic IIX Decoding, dts 96/24 Decoding, dts Decoding, dts NEO:6 Decoding and dts ES Decoding Stereo etc. What ever the AVR get a digital input It will decode the format and convert the same While it in the Auto format mode. If auto format is not selected it will convert the same in to stereo.
Ajin
Feb 09, 2012 | Audio Players & Recorders
Recorder showing these words in window: ERR wish to restore it to folder index where I have important interviews filed.
The ERR indicator is only active if the DVR detects errors related to decoding of video/audio. These errors are due to discontinuities in the received or recorded file data.
Nov 05, 2010 | Olympus VN-4100PC Digital Voice Recorder
My receiver switched from dolby digital to pro logic, but I cannot seem to get it to switch back. It is connected through optical audio to a motorola qip7100 hd receiver. i know that the channels are...
Check the settings in the Motorola to make sure it's outputting Dolby Digital instead of PCM stereo.
Indicators on the receiver can tell you if you're receiving mutlichannel audio or not.
Aug 22, 2010 | Yamaha RX-V995 Receiver
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Decoder problems
OK, use the down mix function on your blue ray player. this will decode for your receiver. the down mix feature should be located in the audio options on the blue ray menu screen.
Mar 16, 2009 | Yamaha RX-V663 Receiver
My Sony DE 945 Blue LED light indicating digital audio reception
Does anyone have a solution? The authorized Sony repair center in my town is stumped.
Jan 16, 2009 | Sony STR-DE945 Receiver
Sony STR de845, 5.1 Surround does not work. 3.2 is indicated o
3.2 IS the "5.1" mode for this receiver. 3.2 is indicating that you have 3 front channels and 2 rear channels. The ".1" is applied to all the speakers (LFE). If you read the manual on page 37, you'll see that "3.2" is displayed with either "Dolby Digital 3.2" or "DTS 3.2". The little icons of the speakers in the display window will show you which channels are active. The bottom line is as long as you see the blue light, it's decoding multi-channel discreet surround sound (at least 5.1).
Nov 22, 2008 | Sony STR-DE845 Receiver
Yamaha RX-V671 7.1 Home Theater Receiver Black Logo
37 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
