Question about KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
KitchenAid kfis27 freezer drawer removal - KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
KitchenAid KBFO42FTX04 bottom drawer frozen shut.thawed but refreezes in 3 hours.Ice crystals everywhere.Icemaker off.How is it freezing shut?
Your freezer drawer is not sealing 100% and room temp. is entering and causing your winter wonderland. The freezer drawer rides on two rails and these rails can get out of sync. One way to correct alignment issue is to open drawer all the way with a little bit of force. Next, close the drawer as fast and as hard as you can. I've used this to correct alignment issue. Sometimes the drawer will need to be removed and reset and other times you might have a bad rail. Good Luck
Aug 15, 2017 | KitchenAid Refrigerators
How to clear out the drain tube on a kitcheaid refrigerator
Freezer has been leaking water at the bottom. I opened the drawer/door and removed the bins, there was a small amount of ice formed on the bottom at the back, I broke it away and poured a small bit of warm water in the black drain hole. the next day the bottom and rear are full of frozen ice and it is difficult to open the drawer/door to the freezer. Everything is covered with frost. Help!
Jun 18, 2014 | KitchenAid KBFA25ER Bottom Freezer French...
Kitchenaid French door refrigerator with freezer drawer in the bottom. Has been in storage for over a year. We plug in and the upper part works fine but we can't open the freezer drawer... Strong tension...
If any moisture was left in the unit prior to storage with the doors closed, it has caused the door tracks to become rusty and non functional. Refrigerator units should always be left ajar for many days following removal of power to allow the interior to fully defrost, and dry out. Extended periods of trapped moisture inside the unit will also cause corrosion on the aluminum coil, and cooling failure. Pleazer Appliance...
May 06, 2014 | Refrigerators
Freezer drawer
Pull the drawer up and out gently towards you.
Sep 16, 2013 | KitchenAid Refrigerators
Fruit is freezing in the bottom drawer of the KitchenAid KSCS25FKSS Side by Side Refrigerator
There is a chance that your refrigerator needs defrosting. Remove everything and unplug your refrigerator, open the doors and let stand for 12 hours. Sometimes the air vents restrict with ice causing this trouble.
http://www.on-timeapplianceplano.com/refrigeratorrepair.html
Jul 23, 2012 | KitchenAid KSCS25FKSS Side by Side...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
KitchenAid KBFA20ER Bottom Freezer French Door Refrigerator Logo
69 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
