My belt broke is all streched out on my washer and i wondering how to replace it
    Problem Solver:
  • 7 Answers
What brand washer,model
Posted on Jan 21, 2009
Maytag washer drum belt worn out....does that damage other parts?
First thing I would do is replace the belt as the old one may have streched
Apr 01, 2017 | Maytag PAV2300 Top Load Washer
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
Washer won't spin unless I give the belt a little push to get it to start moving. The belt looks warn and has a small crack in it. Is the belt the only problem or is there something else I need to...
Sounds to me that the belt defiently needs to be replaced since it is cracked and streched.
Hate to tell ya wait and see but replace the belt for sure and see what happens,but to check a little further if the pulley that tightens the belt(idler pulley) is not missing a chunk of plastic and it spins free when flung with your finger i would say its ok, also you can check the spring on idler pulley by pushing it in and as long as it returns to where it was quickly its ok and just the belt is needed
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 29, 2011 | Frigidaire FWS833A Top Load Washer
The brush on the bottom of the vacuum won't turn when in position to vacuum. I have cleaned the brush, there is nothing tangled around it.
Sounds like the belt is broke, when you remove the brush, be sure that all teeth are still on the belt and that it is not streched. Typically every major retailer will sell these belts usually 2 to a pack and under $10
Jun 24, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Washer wont spin
You may have some small piece of clothing stuck in the water pump. Pull clothes out, empty water out, turn over and remove pump and check for obstructions. If nothing in there see if it is frozen from moving, if not belt may be loose by being streched. Replace belt if needed.
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Agitator not moving
Sounds like your belt has either broke or just come off. Tilt machine back, look under for the belt. If belt looks Ok you still might want to replace it with a new one. Normaly when they fall off they have streched and will not saty on.
Please rate solution
Aug 28, 2009 | Maytag Washing Machines
Belt slipped off machine
rotate pulleys while trying to reinstall belt. if belt slipped off on its own then belt is streched out. replace belt
Jun 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top loading washer model #4420716...it will spin but make very loud noise I am wondering if a belt or something broke...it sounds like the basket is hitting the sides of the washer.
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Check and let me know.
Thanks.
Jun 16, 2009 | Kenmore 24032\24036 Top Load Washer
How do you change the belt if it is slipping?
GN. This model does not have a belt, it's a direct drive washer. It could be a couple of things. Is this happening during spin? If so you may have a worn drive block or something as simple as something between the tub and basket. The clutch and brake assy. could be failing. It's hard telling without being there. I will attach a couple of pictures so you can get and ideal...Catriver..post back.
Nov 04, 2006 | Whirlpool LSQ7533JT Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
