Question about Gigabyte GA-8ID533 Motherboard
I need to knw wat is the video card limite in GA-8ID533 (Rev 1.1) motherboard?
    Sergeant:
    Champion:
  • 242 Answers
If you have a 550w+ power supply you can run a Ati Radeon 3850 HD.
Posted on Jan 21, 2009
Ga-865gvmk-775 drivar dowanlod
hello, i have done some searching for you for driver downloads for your motherboard.
on your motherboard there will be a version number something like this that is printed in white:
Ga-865gvmk-775 rev:1.0 or
Ga-865gvmk-775 rev:2.0
the link for your drivers for ver:1.0 is
GIGABYTE Motherboard Socket 775 GA 8I865GVMK 775 rev 1 0
the link for ver:2.0 is
GIGABYTE Motherboard Socket 775 GA 8I865GMK 775 rev 2 0
hope this helps
thank you
Aug 22, 2012 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I have a GA-7VA (rev.1) board with Athlon XP 2600+, 1.7 GB RAM and 350wat power. I need to upgrade my video card. Game requires Minimum -NVIDIA GeForce 5700 / ATI Radeon x800 and above. Will...
Those are video chips, not cards. You need something like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=555389&CatId=318
Jun 17, 2011 | Computers & Internet
I have GA-8iD533 motherboard. One of my friend tried to flushing the bios, but during the flushing the electricity was gone. After the electricity come i power on the computer,now it shows nothing and i...
To recover your motherboard bios and bring it back to life, you will need this following things:
1. Floppy Drive: It is needed to load the Boot Disk and the new BIOS update.
2. Boot Floppy: It is needed to load the basic operating system, preferably MS DOS.
3. ISA Video Card: Optional, but can simply the recovery process.
Notes:
A startup disk can be automatically built from the Add/Remove Programs applet within the control panel. The boot disk is a vital part of this guide, though users with WinNT/2K will need to build this boot disk from a system running MS-DOS or Win9x/ME.
You can obtain it also from this website: www.Bootdisk.com
Be sure to copy all needed BIOS utilities and update/backup files used during the original flash process to this disk as well.
After making the boot disk, delete the config.sys and autoexec.bat in the boot disk. It can be found in the disk primary directory path.
Create your own autoexec,bat. Using a notepad, build the autoexec.bat file by putting all the command lines in flashing a BIOS.
The approach for using flash utility from AMI or Phoenix is similar, but be sure to read the provided help information about each command line option before building the autoexec.bat entry. Create the text command entry, and then save to the file "autoexec.bat" in drive A: . This will load the command at floppy boot time, regardless of whether an ISA video card is available.
Dec 16, 2009 | Gigabyte GA-8ID533 Motherboard
I need to knw wat is the video card limit in GA-8ID533 (Rev 1.1) motherboard
It supports all 4X AGP cards. The max you can get for 4X is 256MB. Nvidia GeForce series has some nice cards for these specs.
Jan 21, 2009 | Gigabyte GA-8ID533 Motherboard
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
Audio/sound
For the Vista compatible sound drivers of a Realtek AC'97 as used in a Gigabyte GA-8ID533, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Gigabyte GA-8ST800 Motherboard
Motherboard
Hi hamideh, your board can Supports up to 3GB PC100/133 SDR-SDRAM Dual memory module DIMM's
Here is the link to your board.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1402
Enjoy hamideh...
& please vote for me
Mar 08, 2008 | Gigabyte GA-8ID533 Motherboard
Computer stopped responding ! Nothing appears.
Try replacing the Power Supply next.It sounds like it is on its way out.
Please let me know how this works for you.
Thanks
Dec 18, 2007 | Gigabyte GA-8ID533 Motherboard
PCI GA-8ID533 V1.1
there is no PCI lock on any retail boards. But there are IRQ sharings and conflicts. Set IRQ to auto, if not, then manualy and if so, then disable a few things, just to free up some IRQs. All depends on the board, best is to consult the manual for the IRQ sharing table and work with that. (disable one SERIAL, IDE port or USB port if you need an extra IRQ) Also check for onboard equivalent to the card you are adding, disable the onboard part...
Dec 27, 2006 | Gigabyte GA-8ID533 Motherboard
Gigabyte GA-8ID533 Motherboard Logo
88 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
