Question about Audiovox Prestige Code Alarm Remote Alarm Protx6
Have a remote starter that stopped wworking and alarm wont work either.the #s on back of unit are 800 225 6074 fcc elvat
PART NO 073
My alarm wont beep and the remote starter stop working
Check the units fuse if that's ok you may need to replace the alarm devise...
Dec 02, 2013 | C3RS603 2Channel Remote Start Module with...
Remote stop working
You should try replacing the batteries in the remote. If that doesn't fix your problem then you may have a bad remote.
Nov 27, 2013 | 5000RS-2W-1 Remote Starter with...
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
Alarm on 2004 kia spectra wont let me start car
If the alarm is aftermarket I would remove it , I see this problem several times a month , take a test light and test for power at the starter signal wire while someone turns the key to crank this is the small gauge wire going into starter,if there is no power at this wire it will not crank ,if you momentarily apply voltage to the starter signal wire it will crank( also check starter signal fuse)(most alarm systems have a starter interrupt system ,and the aftermarket alarms fail after a few years) Alot of people believe there alarm is factory because it was there when they bought it new but dealer do add alarms that are aftermarket to please there insurance companies
Nov 19, 2017 | Kia Spectra Cars & Trucks
I have a new prestige APS-57C remote starter installed in a 2009 Hyundai Santa Fe and I have a problem with the factory alarm going off every once and awhile. The majority of the time everything is fine,...
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Jan 25, 2011 | Prestige Remote Start
I have a honda pilot with the prestige car starter and the panic alarm keeps going off when I open the door. I can not get it to stop so it has to go through its 2 minute cycle. any ideas on how to get...
That is your factory alarm. I will assume that this Prestige unit is a remote starter with keyless entry...and you are using the Prestige unit to unlock the doors. Apparently, the unlock wire is connected but, the factory disarm is not. You can turn off your factory alarm by unlocking the vehicle with the key.
Will the excalibur touch remote work with another excalibur alarm i dont have the alarm model number but do have the alarm that i have on my car remote fcc # and it is a remote start alarm too the fcc...
The Touch remote can be used with any Echo compatible systems. These systems can be identified by their model numbers. Systems ending in E, EDP and EDPB are Echo compatible.
Dec 11, 2010 | Vehicle Parts & Accessories
Alarm is stuck in valet mode
This will work for many alarms, but not all:
Locate valet push button, may be hidden on or under dash somewhere. Turn on ignition, doesn't have to be started. Then push and hold valet button for a few seconds. Most alarms will chirp to confirm operation was a success.
DEI products require a slightly different procedure, and drivers door has to be open.
Some can be done through the remote.
Model of alarm will help alot, or FCC ID from back of remote. DC
Nov 04, 2009 | Vehicle Parts & Accessories
2005 Pontiac Grand Prix Alarm Problem
you need to go to an alarm installer and have them disarm the alarm. If you try to disarm yourself, you could possibly damage computer configurations.
Aug 04, 2009 | 2005 Pontiac Grand Prix
Audiovox Prestige Code Alarm Remote Alarm Protx6 Logo
Top Prestige Appliances Vehicle Parts & Accessories Experts
xxxxxx xxx
Rocguy
Tim Marx
Tim Marx
Are you a Prestige Appliances Vehicle Part and Accessory Expert? Answer questions, earn points and help others
