Question about 3M Transparency Thermofax Tattoo Stencil Maker Thermal Copier
Thermofax runs properly but isnt transferring the image for a stencil, what is wrong?
My cricut mini wont cut. an error appears and says that the images arent on the mat properly and will be skipped
I am having this problem also. The image i wish to cut is well inside the 12 inchs. Hope someone has the answer
Oct 30, 2016 | Crafts & Hobbies
Ricoh sp c830dn running transfer paper for tshirt transfer. the toner is not adhering properly. poor transfer and ghosting. have tried various paper settings such as thick and special. no help have heard...
If it works fine for paper but not this application the machine is not designed for what you are using it for. You will damage the fusing unit. When it does not properly fuse the image the heat is insufficient and thus it does not transfer the image properly. Use the thickest paper type for best results.
Oct 09, 2013 | Ricoh Aficio Office Equipment & Supplies
What is screen printing?
You have a stencil and use this to print ink in a design onto a material. You can also use more than one stencil to make different colored images. This is also known as silkscreening or serigraph printing.
Jan 10, 2013 | Crafts & Hobbies
Thermal machine will not shut off after stencil completion
DO NOT purchase from rouben@ektalc.com
He is dishonest and not good to do business with
Nov 09, 2012 | Office Equipment & Supplies
Thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
Mar 30, 2009 | Office Equipment & Supplies
I have a 3m thermofax 45cg every paper run through is completely
I am a major seller of these machines in ebay. The machine may need a new potentiometer. Build a carrier. Put two pieces of transparency plastic sheets together with a piece of tape and use this to carry your stencils. This will reduce the heat of the lamp. Rouben (rouben@ektalc.com).
Mar 23, 2009 | Office Equipment & Supplies
97 KIA SPORTAGE ENGINE NUMBER LOCATION
you'd have to remove the engine its on the back.
Aug 20, 2008 | 1999 Kia Sportage
3M Transparency Thermofax Tattoo Stencil Maker Thermal Copier Logo
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
