Question about DC Shoes Winter Sports
The hooks of my boots lost, how can i find the repair kits
Dell xps will not boot ubcd
The cd-rom in the M1730 might not like the type/brand of disc you are using. An alternative would be to remove the HDD from the laptop and either put it in an external enclosure or get an adapter kit and hook it into another computer all together to recover your data. You can also try to make a bootable USB drive in order to boot the computer.
Apr 03, 2013 | Dell XPS 1330 1730 M1210
Craftsman chainsaw fuel line and fuel filter
go to sears and purchase the fuel filter and fuel line kit for the chainsaw. in that kit will have a hook that you fish through the outside of the tank to the inside, you attach the new fuel line after attaching the fuel line to the fuel filter, to the hook, then pull it through the hole. disconnect the hook from the fuel line, cut the small piece off where the hook made the hole and attach to the carburetor. finish by pushing in the fuel filter inside the fuel tank. the kit will also have more detailed instructions and possibly with illustrations. if sears doesnt have the kit, check with a lawnmower repair shop.
Sep 19, 2012 | Craftsman Garden
Lost power early this morning and now the green light is flashing - reset does not help No picture and no sound
Thats a very common problem caused by weak capacitors on the DM board. When they drain they cant recharge when power is restored. The Mitsubishi repair kit called the WS48511 - WS55511 DM repair kit from www.tvrepairworld.com is the kit that will usually repair the issue. The kit contains the Capacitors and the CD with repair instructions.
Sep 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Green light on front of TV keeps blinking after power outage. I have tried powering back off and on and resetting the tv. Nothing works
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
Aug 02, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power wet off and now the timer green light is flashing and it wont turn on model # ws 55511
Thats caused by the 7 capacitors on the DM power board. They discharge when the power is lost and then cannot recharge when power is restored and the indicator light will blink non stop indicating the DM has not completed the boot sequence. Replace the DM caps. The WS48511 - WS65511 DM repair kit is the correct repair kit for your model. You can get the repair kit from www.tvrepairworld.com
Jul 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Manual shifter popped and i lost 1st. /2nd pulled boot plastic cam assm. now what. 2003 fonger1@juno.com
get a saturn shifter bushing repair kit, cost about 20 bucks at parts store or on ebay. take about 2 hours to do the whole project, you have to pull the console first, and you have to have a warm place to work.
Jan 05, 2011 | Saturn Vue Cars & Trucks
RIGHT CV JOINT LEAKING PLEASE ADVISE
you can replace just the boot,its not hard to do,buy the repair kit @ your local parts store,they have kits were you dont even have to take off the tire,the boot splits with clamps to hold them on-
hope that helps
Nov 06, 2010 | 2004 Honda CR-V
Modle model hd52w67yx66 lost convergance pic has three colors in main menu no convergance option like when new open for sugestions tuner and sound ok
Thats a easy and inexspensive repair. www.tvrepairworld.com has the RCA repair kit called "ITC222 and ITC222A convergence option missing repair Kit" The kit contains the components and the CD with detailed repair instructions.
Dec 22, 2009 | Televison & Video
It keeps blinking but the TV won't turn back on. I have tried to reset it and have also unplugged it.
the dm isnt booting up if the led is contantly blinking. The V26 DM repair kit will usually repair that issue. You can get the kit at the following link which contains the replacement capacitors and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Jul 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Where do I hook up the R-134 AC repair / recharge kit?
look back near the firewall right beneath the bottom of the windshield. There is a small black cover that you unscrew, and hook the ac recharge kit onto. Then just follow the directions on the can.
Jul 16, 2008 | 2001 Ford Taurus
Winter Sports Logo
96 people viewed this question
Top DC Shoes Winter Sports Experts
Todd Arndt
Todd Arndt
Are you a DC Shoes Winter Sport Expert? Answer questions, earn points and help others
