Question about EnGenius ERB9250 300Mbps Wireless N Range Extender
Not connecting to internet
Connects to router but not to internet from distance. get yellow triangle with ! in it
Im connected to my wifi internet in the office but i cannot open the internet . the brand of router is cisco WRT54G2VI, SERIAL #CSVO1HC21627, MAC.ADD 002369214852, ARROW SYMBOL UP DOWN 45103834, please...
If your computer shows you the little yellow triangle (limited connectivity) then you might have to reset the source of your internet, the modem if you can access it, by unplugging the power for 30 seconds. then reset your router by unplugging the power for 30 seconds so it can aquire a new IP address if you get the internet through dynamic settings. The router could also have a bad ethernet internet port. If you can connect to the router wirelessly and tried resetting it and if you can get internet being directly hooked up to the modem or source of internet such as a wall outlet...then your router may be bad.....if it is a Belkin...then it was junk to begin with.
Aug 28, 2013 | Cisco Computers & Internet
Connected to the network but no internet access
tried to hooked up the LAN cable directly to the modem bypass the router if you can get an internet access there.
Nov 02, 2012 | TP-LINK TLWR340G Wireless Router
Connecting acer c100 to internet
hi, have you added the device (c100) to the router access list under wreless settings , the clue would be a yellow dot or triangle in the wireless logo on the c100 showing restricted access?
Jul 07, 2012 | Acer (91.48R28.006) for TravelMate C100...
I cannot conneft to the internet. I have the yellow triangle in the task bar at the bottom
YELLOW TRIANGLE MEANS UR SERVER IS DONE/BUSY.CONTACT UR SERVICE PROVIDER FOR THIS
Mar 10, 2012 | Computers & Internet
It says my Linksys internet is connected but it has a yellow triangle next to it and won't let me go on the internet. It worked a week ago but isn't now. It doesn't even work if I plug it directly to the...
you need to unplug the router then plug it in i use one of those swiches that turns your lights on and off every day to reset it i know its annoying
Jan 17, 2011 | Computers & Internet
From a point on the ground, a person notices a 110-foot antenna on the top of a hill subtends an angle of 1.5 deg. If the angle of elevation on the bottom of the antenna is 25 deg, find the height of the...
Draw one right-angle triangle:
D
C
A===B
A = your location
B = bottom of the hill
C = bottom of the antenna
D = top of the antenna
The A-B distance is constant.
The B-C distance is unknown.
The B-C-D distance is unknown.
The C-D distance is given.
The C-A-B angle is given as 25 degrees.
The D-A-C angle is given as 1.5 degrees.
Use SINE and COSINE functions to determine the B-C distance.
Tell your teacher that you found the answer to your homework on the Internet.
Sep 24, 2010 | Computers & Internet
I get a yellow triangle
Usually mean you are not connected to the internet either not to the internet modem or the modem is not connected. Try a fresh LAN cable between the modem and router. Make certain your modem is connected to the internet and working - if not check with your internet provider. Reboot you router.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Jul 30, 2010 | D-Link DSL-G604T Wireless Router
Gateway laptop and 2wire router AT&T can't connect to network
On your 2wire router is model number, below that is another set of numbers, from network connections select your 2 wire router, then connect. it will ask you for a password, The password is the set of numbers below the Model No.
Jul 05, 2017 | 2wire (1000-000057-000) Modem
Intermitnent wireless connection problems
There are two reasons for fluctuating wireless signals .
1. There is interference by way of microwave, hard cement walls, cordless phones, etc 2. The firmware of the router needs to be updated .
Either of these is the reason for your problem. Hope this helps .
Thanks
Ranjit
Aug 10, 2009 | D-Link DGL-4500 Wireless Router
Open Questions:
See all EnGenius ERB9250 300Mbps Wireless N Range Extender Questions
EnGenius ERB9250 300Mbps Wireless N Range Extender Logo
22 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
