Question about Scosche Industries Scosche Tuneit Goose Neck Fm Transmitt Mpn Fmtd3
Scosche FMTD3 transmitter wont turn on anymore
I plug it in to my vehicle and for some reason it wont turn on anymore. Is there a way to reset it? Or what do I need to do?
  • austin hewitt Mar 16, 2019
    I have a scosche BTFREQ Bluetooth transmitter and when you plug it in the screen lights up and doesn't show anything
    New Friend:
I had this issue and the solution to my problem was that there is a spring inside the transmitter that no longer was pushing the outer pin all the way out and therefore no longer completing the circuit. To resolve simply open it and with some needle nose pliers pull out the spring and reattach the cover this time the pin will reach and turn on. I hope this helps.
Posted on Jun 20, 2016
    New Friend:
Try raising the volume on your phone to the max, it should come back on
Posted on Jun 14, 2016
    New Friend:
I have this problem currently and was wondering if you have found a solution yet?
Posted on Feb 08, 2016
    New Friend:
Same problem with mine a couple months after purchase.
Posted on Oct 09, 2015
SOURCE:
I have a FMTD3 and have no idea what it does. HELP!!!!! I recently purchased a MONTE CARLO S.S.a 2000 model year when I cleaned the trunk out I found this electrical device
The TuneIt FM transmitter plugs into the 3.5mm jack of your iPhone, Smartphone or other mobile devices to provide a clear and crisp audio signal through your car stereo. Use the integrated aux cable to plug the TuneIn into the headphone jack of your device.
https://www.google.com/search?client=firefox-b-1-ab&ei=iTlpWsjHHIWKjwTDyJvABA&q=fmtd3+review&oq=FMTD3+&gs_l=psy-ab.1.3.0j0i30k1l3.19849.19849.0.22979.1.1.0.0.0.0.121.121.0j1.1.0....0...1..64.psy-ab..0.1.120....0.BpCKPvT8DQ0
Jan 25, 2018 | Chevrolet Monte Carlo Cars & Trucks
Why does my scosche corded fm transmitter say loading and does nothing else?
A component on the mother board may have defaulted. May need replaced. Or a wire or cable is disconnected. Try rebooting the system.
Mar 11, 2016 | SCOSCHE Corded FM Transmitter for...
How can I get a replacement cord or have the cord repaired?
If it is a coax cord you will either need to order one from the manufacturer or make one from parts found at an electronics store if you can find or online.
Sep 06, 2015 | SCOSCHE Goose FMTD3 Neck FM Transmitter...
Scosche FM Transmitter won't change stations and is just lit on 107 and won't change . What's the problem?
Bad transmitter, open the back side after in plugging it and check the brass contacts for continuity!
Nov 11, 2014 | Audio Players & Recorders
How do i use scosche fm transmitter
You plug your mp3 player into it and then it broadcasts the audio to any FM radio that you are near. so it is a wireless connection like bluetooth for sending your music to a car radio without wires.
May 15, 2014 | Scosche Industries Scosche Fm Transmitter...
Scosche Fmtd3r Tuneit Universal
Replace the fuse, if it keeps blowing then most likely the unit is defective and will need to be warrantied or replaced.
Jan 31, 2014 | Scosche Industries Scosche Tuneit Goose...
Scosche fm transmitter FMTD8 not playing mp3 files on Flash drive
I bought the fmtd8 scosche transmitter. If you're like me ,you tried to play music from you're cell phone first. That worked just fine. Then I made an sd card with a few hundred songs on it. P.S. I left the audio cable plugged in the the transmitter. The sd card with mp3. songs would not play for anything. After 2 days of trying,I finally decided to unplug the audio cable.. Voila!!!!! Instant sound.
Dec 28, 2012 | Car Audio & Video
Xs1100 spark at plugs when turning ignition of
theres 3 main reasons a vehicle wont start: no spark, no fuel or not enough fuel pressure, or the engine cant breath
Jul 12, 2012 | Motorcycles
Scosche FMTD3 FM Transmitter - metal thimble at end of device not extending and seem to have losts its force to extend. What internal parts give tension to this metal thimble?
Unscrew the end and replace the fuse. it should be a 1A250V and you should be able to tell if the fuse is blown. After replacing the fuse, see if it works. If it doesn't please let me know and I will try to help you find the problem.
Sep 10, 2011 | Apple Audio Players & Recorders
I recently bought a Scosche Digital FM Transmitter Model FMTD8/FMTD8R. I loaded my 8GB San-disk flash drive with music but the transmitter won't read it.. doesn't even detect the flash drive being...
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
Jun 11, 2011 | GPS
Scosche Industries Scosche Tuneit Goose Neck Fm Transmitt Mpn Fmtd3 Logo
3,040 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Vincent G
Vincent G
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
