Question about Acer Computers & Internet
FOXCONN M7VMX, N15235 MOTHERBOARD - EVERYTHING OK BUT NO DISPLAY, AND KEYBOARD LED NOT LIGHTING
PROCESSER FAN WORKING, MEMMORY CARD OK, NO DISPLAY, KEYBOARD LED NOT ON, I THINK BIOS PROBLEM
tazmancool
SOURCE: drivers
for drivers on M/B FOXCONN N15235 all dirvers go to www.quebex.com, also will include the direct link, and click on model APOLO_48XX and have fun downloading all needed drivers...
http://www.qbex.com/website/downloads.php?osCsid=83c184775bfaf6771df03e7fc3bdb41a
Posted on Sep 17, 2009
SOURCE: xp sound driver for foxconn N15235 MOTHERBOARD
you can goto http://www.foxconnchannel.com/support/downloads.aspx and download the drivers for your model!!!
Posted on Aug 11, 2008
  • 139 Answers
SOURCE: Foxconn N15235 Graphics Card
Most Graphics cards will work. But, you can email foxconn or go to their site to see which cards the recommend
Posted on Sep 03, 2009
  • 1481 Answers
SOURCE: I have motherboard MSI MS-6787 VER:1 2.8GHz 1GB
check compatibility....
Posted on Jan 04, 2010
  • 145 Answers
SOURCE: A 14 month old Acer aspire M1640 wil not show any
YOU MAY HAVE A BAD MOTHER BOARD
Posted on Jan 08, 2010
No display cpu fan and led indicators are working fine.Iam using RoHS Compliant N15235 motherboard.Can u tell me what will be the fault?
I don't know much about these things but I understand if everything is ok there is an audible beep shortly after switching on, at least all of my pc's have beeped. According to my motherboard manual there is all sorts of beeps as an aid to fault diagnosis.
As there is no display perhaps there is something wrong with the graphics card. It looks as though your motherboard has on-board graphics and it might be best to use those initially with a known good monitor.
Jun 25, 2016 | Computers & Internet
No display from n15235 hp mother board why?
Connect your monitor to a different computer and see if you get display. If no, then the monitor has failed. If yes, the integrated graphics card on your motherboard has failed. Delete and reinstall the motherboard drivers that came with the computer. If still no video, you will need to buy a video card and install it. You have a PCIe expansion slot, so a video card will fit in it.
Here is the link to the specifications of your computer:
http://www.findlaptopdriver.com/foxconn-n15235-motherboard-specifications-12242011t87/
Jul 25, 2014 | HP Computers & Internet
HI,I have a foxconn 45CMX Motherboard of a pinless 775 processor type,has two RAM slots ,16xPCI-E1,1xPCI-E1 slots and two PCI solts where I plugged my tv Card, 4 SATA slots and 1 IDE solt, it has a...
Hello nvukeya
You have described the computer very well in details.
as for the problem what i understand is that the only light coming on at the front of the case is the power light.
From past experience this problem is caused by one of two things.
1- faulty power supply. even though the power light comes on the power supply can be faulty
2- faulty motherboard.
While I am sure it is one the above items still you can go through the process of elimination.
To eliminate other components you can remove the TV card an if you have a floppy drive make sure to disconnect that too. then the computer. if you have more than one stick of RAM you can try them one at a time.
hope this has put you in the right direction.
please leave comment if this has been helpful
Dec 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Foxconn motherboard n15235 no viedio
That motherboard is either a P4M800P7MB-RS2 or a P4M800P7MB-RS2H, even thou it has N15235 stamped on the board. The board
Supports VGA display function (S3 Graphics UniChromeTM Pro IGP)
but, also has an AGP 8X slot. A slot that allows you to install a AGP 8X (AGP 3.0) card. A AGP 8x is the VGA interface specification that enabled enhanced graphics performance with bandwidth speeds up to 2.1 GB/s.
Hope that answers your question.
Mark
Apr 23, 2010 | Foxconn 6627MA-RS2H Motherboard
Connect power swithc and led cables to foxconn n15235
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
http://www.foxconnchannel.com/en-us/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Mike
Nov 10, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Drivers
Jun 17, 2009 | Computers & Internet
Replaced motherboard, no signal on monitor
IF THE COMMUNICATION PORT FOR YOUR DEVICE IS NOT UNBOARD THAT IS IF THE KEYBOARD, MOUSE AND YOUR VGA CARD ARE THE REPLACEABLE ONE, TRY TO CHANGE THOSE CARDS THEY MIGHT NOT OK ANY MORE. IF YOU STILL HAVE SAME PROBLEM THEN THE MAINBOARD IS NOT OK, ALSO, YOU CAN CHECK YOU MEMMORY CARD THAT IS RAM IF YOU DON'T ATTACH IT PROPERLY IS CAN CAUSE THE PC NOT TO BOOT. IF IS RAM FAULT YOU WILL BE HEARING SOUND FROM YOUR BOARD, ATTACH IT PROPERLY.
Nov 19, 2008 | Compaq (203966-001) Motherboard
Help Please
You're Foxconn N15235 must be in a PC case from another Mfg.
EX: Packard Bell IXtreme 2711. Please tell me what machine the board is in. If its the above system than it can take Two 240-pin DDR2 SDRAM DIMM slots. Single Channel DDR2 400/533.
Supports up to 2 GB system memory.
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
